i took home a P200MMX today, without proper ESD sensitive packaging. I wrapped it in aluminium foil instead. Will post back to see if I killee th proc.
Transporting CPUs w/o proper ESD-safe packaging
Tags: None
Re: Transporting CPUs w/o proper ESD-safe packaging
it'll be fine. you'd be amazed how much abuse computer hardware can take.
as an experiment, myself and a buddy put a 512mb stick of hynix memory in the microwave on HIGH for 10 seconds, and it survived. How is beyond me, spparks were dancing off it, and it was hot as hell, but it still worked.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
Originally posted by Topcatit'll be fine. you'd be amazed how much abuse computer hardware can take.
A related example: in an organic synthesis laboratory, one regularly works with very toxic or reactive compounds, and yet virtually all (serious) accidents I've ever heard of, or experienced first hand, were the result of broken glassware.
Moral of the story: what people fear the most isn't what's going to kill them.Comment
I tried it in an Asus P5A board, nothing. I prob didn't set the jumpers right. I'll try switching it out with an other 200mmx.Comment
by ugamazingI have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%... -
Hi guys!
I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
I have attached the Dump of my machine.
S/N: SRW2K4J
Reg Model: DCTR...-
09-27-2024, 02:43 AM -
by ducky29Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
Thanks in advance.09-23-2024, 03:56 PM -
by unimatrix93Hello everyone,
I'm trying to fix up my battery charger. Where I found a dead schottky rectifier.
This is the dead component PTR30L120CTF:
PTR30L120CTF datasheet(1/7 Pages) PFC | 30A 120V HPTR Schottky Rectifier (alldatasheet.com)
And I have a spare 30CPQ150:
30CPQ150 datasheet(1/5 Pages) IRF | SCHOTTKY RECTIFIER (alldatasheet.com)
Can I use this diode as a replacement or if not, can you recommend me a proper replacement?
I cannot find the exact unit anywhere besides aliexpress and such.
Thank you guys!
Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
tags:...07-28-2025, 07:26 PM - Loading...
