Overclocking 101
  • weirdlookinguy
    • Sep 2007
    • 1638
    Overclocking 101
    Hey guys, my main rig has the following gear:
    Gigabyte EP45-UD3P
    Core 2 Duo E7500, stock Intel cooler
    4GB G.Skill 4-4-4-12 1.8v stable RAM
    I have been running her at stock speed for two years now. I know that my motherboard was supposed to be one of the best for overclocking when I bought it, and I know that C2Ds are supposed to overclock real well.
    Unfortunately I don't even know where to start when it comes to overclocking. Can someone give me a quick crash course in overclocking?
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Overclocking 101
    Egads. Where to begin?
    Here's a couple of guides, one of which I skim read before I posted:
    http://hexus.net/tech/tech-explained...ide-beginners/
    http://www.tomshardware.com/forum/25...clocking-guide
    I'd say, before you begin, make sure it's all cleaned out. Running it for 2 years has probably resulted in some dust in the heatsink and other parts. You want good cooling for overclocking.
    Also, I wouldn't try upping the voltage much with the stock cooler. Obviously measure your temperatures and go from there, but keep a particularly close eye on them.
    Read through the guides then come back if you've got any questions.
    A man convinced against his will is of the same opinion still.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      lets see... first, kiss any hopes of your computer being quit goodbye.
      second, be sure you have a backup system rrady for use, as overclocking can be risky buisiness.
      finally, considering how you designed your rig, i would reconsider overclocking. your design was to keep it quiet while still having power to burn. an overclocking rig is usually very loud.
      sigpic
      (Insert witty quote here)
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Gigabyte EP45-UD3P
        There's no real science around overclocking, just play with the FSB and multiplier settings until the computer becomes unstable or doesn't boot. When that happens bump the voltage if the computer still doesn't boot or run stable then something is holding you back, usually north-bridge, memory, or power-supply.
        Watch the temps at idle, if it sits at 55*C or higher you got a problem. If it remains in the 40's you're okay since full load temps will be 10* more.
        You can use speedfan to monitor temps.
        Once you hit your desired clocks, use Prime95 or Orthos and let it run for 24 hours. YOU MUST RUN IT FOR 24 HOURS TO DECLARE YOUR COMPUTER STABLE!
        I've had computers which appeared stable only for them error out after 16 hours.
        Some run it for 72 hours, I say that's overkill.
        Watch your temps when you're doing a stress test, it can creep up and something cooks.
        Don't keep pushing it.
        What I mean is, if you already push the voltage up to 20% of the stock voltage and the computer is not stable, I would back off and be happy with what you got, otherwise you'll fry it. Or if the temps are too high I would back off and get better cooling.
        If you're still persistent then mess with the northbridge voltage and memory timings along with voltage to see if that breaks the FSB wall.
        If it doesn't then it's the processor.
        HTH
        ~Mp
        • acstech
          GrumpyModerator
          • Jul 2007
          • 1432
          You might want to see what the limit is for each component (processor, memory, FSB) separately, take notes, then put together an overclock that is within the limits of each component.
          I've been using a program called "Intel Burn Test" to verifiy stability. It loads the processor up more than anything else I've seen. Probably the best way to do it would be to verify stability with multiple programs. Run IBT, since it completes rather quickly, while you're working up your overclock. Then when you find settings that you like, run P95 for 24+ hours, and whatever else you can think of to throw at it.
          http://downloads.guru3d.com/IntelBur...load-2047.html
          • weirdlookinguy
            • Sep 2007
            • 1638
            I'm not very worried about that, it's not like I am doing anything permanent to the computer. I just want to boost the processor speed a little. If the fan starts whining I will bring that shit back down to stock speed so fast it would make speedy gonzales blush. I don't fuck around with loud computers.
            I'll see how Photoshop CS5 runs on it, my brother is going to start using my computer for Photoshop and that's the main reason I am considering overclocking (since PS is so CPU intensive). If it runs fine, then I'll probably leave it as-is. If it lags then I'll give the CPU a shot of nitrous.
            • toastygoodness
              • Jul 2005
              • 813
              the best stability program i've had was core damage (which really can damage your cores if your heating is bad). see here: http://damage.vigilantesoftware.com/
              first thing i'd do is make sure ventilation is all set -> new thermal paste applied correctly (good thermal paste too), clean out fans/heatsinks, if you have sleeve bearing fans make sure to oil them, etc.
              then it's really just a matter of locking your PCI-express clock to 200 or whatever it is, then changing the multipliers or FSB of the CPU. you might want to downclock your RAM all the way just to see the peak speed you can hit, then start messing with it after.
              those links posted are good starts.
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • AkaBukai
                Is it okay to flash stock bios onto the motherboard's BIOS?
                by AkaBukai
                Hi there,
                I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                The little LED on the power button is flashing slowly and nothing happen.
                This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                So I decided to flash the BIOS using a cheap programmer.
                And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                I also...
                12-19-2024, 12:15 PM
              • ignacio.ino27
                (BIOS) Asus X541UVK Rev 2.0. Stock ME REGION
                by ignacio.ino27
                I share with us this binnary file that i have edited the ME Region (from original dump version to stock 11.6.0.1126).
                It is "stock" region and working.
                BIOS: X541UAK.306
                MOTHERBOAD: X541UVK Rev. 2.0
                CPU: Intel Core i3 7100U Kaby-Lake R
                ║ Family │ CSE ME ║
                06-08-2021, 05:39 PM
              • ArtMov
                [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                by ArtMov
                Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                1. I made overclocking lock disabled the default in amibcp
                2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                03-31-2023, 01:30 PM
