uses for old psu parts
  • Elitist
    • Apr 2006
    • 159
    Re: uses for old psu parts
    Whilst we are on the topic of PSU mods., I recommend swapping the leads from old AT supplies into modern mission-critical ATX units because they are invariably of thicker gauge. It'll be necessary to double colour-code the 3.3V leads, however, as there weren't any orange leads on AT.
    • Rainbow
      • Aug 2005
      • 1375
      Some ATX PSUs (the better ones) have 16AWG wires, cheap ones have 20AWG.
      • tiresias
        • Feb 2006
        • 489
        Indeed. The Enermax units here have invariably 16AWG for all the high current-bearing lines. The Liteon-made SM one has 16AWG for almost every output cable. On the other hand, the cheaper ATX300-series Fortron uses 18AWG wire in the same places, while that atrocious "Codegen" device that destroyed of the parts in my cousin's computer used only 20AWG, and a measly 24AWG for the PSON, PG and such.
        It is said that net (cable-free!) weight is often a gauge for a PSU's quality - I agree, and would add cable gauge as another.
        • Chris1992
          • Apr 2005
          • 561
          A Bestec in my spare parts pile has 22AWG for the +12V P4 connector. 18AWG for the ATX 20-pin connector, and 18 for the molexes.
          The great capacitor showdown!
          • Elitist
            • Apr 2006
            • 159
            I lost my WG measure decades ago and can't find the SWG to AWG conversion. Another confusing trick is to use fatter insulation, presumably to save copper, whereas, if the correct copper gauge is selected in the first place, iR drop and i2R heating should be so negligible that the insulation thickness becomes irrelevant.
            • Rainbow
              • Aug 2005
              • 1375
              #26
              My 200W DTK PTP-2007 (Macron Power OEM) has 16AWG everywhere.
              • PeteS in CA
                • Aug 2005
                • 3586
                • USA, Unsure of Planet
                #27
                Often the AWG is printed on the insulation, along with the brand name and safety agency info. One thing to be aware of is that, with the two most common (in the US anyway) wire types, UL 1007 and UL 1015, these use the same type of insulation, but the insulation wall is thinner with UL 1007. So you either have to read the printing on the insulation - got magnifier? - or look at the actual wire inside to see how heavy it is.
                PeteS in CA
                • Elitist
                  • Apr 2006
                  • 159
                  #28
                  Not sure where the EU is with cable labels. Seem to have mains cables (is this the third incarnation of colour coding changes?! black and red was just so intuitive till the bureaucrats started interfering!) and always have had coax labelled, but not regular multistrand.
                  • PeteS in CA
                    • Aug 2005
                    • 3586
                    #29
                    If something isn't broken, government usually fixes it till it is.
                    PeteS in CA
                    • Elitist
                      • Apr 2006
                      • 159
                      #30
                      Took another look at some of my more recent PSUs. Some of them are clearly intended for world markets, have 240/110V switches, etc and a few have cabling marked in AWG (which tends not to be used outside the USA in other contexts). 20AWG seem common, but feels too thin to me! AT supplies were always much thicker, even on cheap clones.
                      • yanz
                        • Nov 2004
                        • 910
                        #31
                        agree! i've done it many times before.. i found them usually 18 awg even 16 awg! my aibo's (LC) cable is of 20 awg. if you search for cable splitter (molex conector) in the shop you even get 22 awg!!
                        be careful with soldering them to the old holes, as sometimes it wouldn't fit and you'll need a drill. but be carefull!!
                        days are so short when you actually do something..
                        • Elitist
                          • Apr 2006
                          • 159
                          #32
                          You are correct. It's not just a question of drilling out the holes, but it's easy to overheat the solder, which can cause the tracks to lift from the pcb - especially on the cluster of earth (black) leads. A thermostatically controlled soldering iron would be ideal, if somewhat expensive!
                            by momaka
                            03-12-2025, 03:42 PM
                          • Mark D
                            Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                            by Mark D
                            The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                            10-29-2024, 03:15 PM
                          • flibidy
                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                            by flibidy
                            I have here a Magnum IA.100 which belongs to my parents.
                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                            What Ive done........
                            01-01-2025, 01:26 PM
                          • 2elw
                            SVOD4 PCB pictures + parts
                            by 2elw
                            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                            GW1N-UV9UG169C6/I5 FPGA - Its a...
                            07-04-2025, 12:23 PM
                          • SurrealMustard
                            What parts can be salvaged from a plasma with a damaged display panel?
                            by SurrealMustard
                            I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                            03-09-2025, 08:29 PM
