More memory or less memory than speed?
  • patriciopat
    MerlinMac
    • May 2007
    • 68
    On a computer with i3 core to 3.2 that comes with 4 GB of DDR3 1333Mhz, if memory conbined with other 4 modules of 1024Mhz, the bus goes to work at 1024Mhz ... the difference is very noticeable in performance or is it better to have 4 gigs of ram to 1333 rather than 1024? thank you very much
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: More memory or less memory than speed?
    It is slowing down to reduce loading on the RAM BUS and RAM Power.
    Which is better depends of what you do with it.
    For most people 4GB is more than they actually use anyway.
    If you have a 32-bit OS then it won't use more than 4GB even if you have it.
    If you are not a gamer and you don't do CAD or some kind of graphics processing then 4GB is enough. [Probably more than enough.]
    I would choose the 4GB at 1333MHz.
    If you want more then use 4 x 2GB modules.
    Fewer -modules- will reduce the load and it -might- even run at 1333 that way.
    Mann-Made Global Warming.
    - Dr Seuss
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      The 1024MHz is throwing me off, but what I think he means is that he has 4 Gigs (presumably 2x2GB sticks) running at 1333MHz, and he has 4x1GB that are rated for 1024MHz (1066?). That means it would run the 1333MHz sticks at 1066MHz, but he would have twice the ram. I think what he wants to know is if it is faster to have more, slower, ram or less but at a faster speed
      ...(which you did answer, and I agree with that answer.)
      Although, it's a i3 and I'm guessing his motherboard has 6 ram slots so he can run tri-channel with it, though it would still be at 1066MHz.
      • patriciopat
        MerlinMac
        • May 2007
        • 68
        So which is faster A1064 8 gigs of ram or 4 gigs of ram to 1333? I refer to levels of performance, and if you would notice a lot ... the OS is MacosX ... thank you very much friends
        • digge
          • Apr 2006
          • 296
          Depends on what kind of application you have. Not sure about osx since ive never used it a lot but most operating systems have some kind of system monitor. I would take a look there, see how much ram youre really using compared with what you have.
          Beware though that at least for linux the model for how memory is managed is different. Linux will allocate memory beforehand and report it as used if youre not looking in the right place.
          For my own purposes i would go for the 8gb of ram, cause of the way i use my comptuter. I always have 50-100 tabs in webbrowsers open as well as maybe a game running. Thats not how all people use their computers though
          So in short, look into how much memory you are actually using now and from that make a decision on what is best for you.
          • patriciopat
            MerlinMac
            • May 2007
            • 68
            Thanks, what is not is if someone has done it, but hey I have to pass some test to see how it behaves in a stable system or not ... I is to take advantage of the modules, although it is true that memory now this cheap ... thank you very much ... greetings and best soys
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Like I said before, that depends on what you do with it..
              If you are an average user then you probably don't -actually- use more than about 2 GB of RAM anyway and the 1333MHz would be faster.
              I've attached a typical RAM vs Performance Curve.
              That extra 4GB will probably gain less than the lower speed will loose.
              - But as said by 3 people now,, it depends on what you do [apps] on the PC.
              - Dr Seuss
              • patriciopat
                MerlinMac
                • May 2007
                • 68
                Thanks for the help, soys the best ... I love this forum.
                • Evil Lurker
                  Warranty Voider
                  • Feb 2011
                  • 454
                  Lets not forget about latentcy timings either...
                  • inuyasha.rules
                    • May 2011
                    • 43
                    Osx is 64 bit so you can use more than 4gb ram, but as others said WILL you use that much? So the long answer is it depends on what you do. Gaming, faster ram will help, browsing the entire internet or working with large files, as much ram as you can stuff in it. But if your that worried about it get http://www.newegg.com/Product/Produc...82E16820231351 and buy as Manny as it will hold. (Note I can't get the compatibility wizard to run on my phone so double check to make sure its compatible)
                      Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:21 AM
                    • kokodin
                      memory mod for amd radeon r7 260x
                      by kokodin
                      Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
                      I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
                      In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
                      03-28-2024, 03:48 PM
                      HP Pavilion p6-2008nl Pavilion p6 i7-2600 Specification for Upgrade or Repair
                      This specification for the HP Pavilion p6-2008nl can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion p6-2008nl boardview and Pavilion p6-2008nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 03:30 PM
                      HP Pavilion p6-2150en Pavilion p6 i5-2320 Specification for Upgrade or Repair
                      This specification for the HP Pavilion p6-2150en can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion p6-2150en boardview and Pavilion p6-2150en schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      09-12-2024, 03:28 PM
