I have a problem with installing XP on optiplex 780
  • Wizard
    • Mar 2008
    • 2296
    Hitachi 500GB, optiplex 780 tower.
    Results in 0x0000007B every time at preinstall stage after loading basic drivers.
    I tried both pre-install SATA drivers from Dell by slipstream them into XP install disc using nlite and still get this ....7B blue screen.
    And this partition and formatting stage is not even started.
    Cheers, Wizard
  • mockingbird
    • Dec 2008
    • 5484
    Re: I have a problem with installing XP on optiplex 780
    Download a new XP ISO and try loading it in non-AHCI mode. If it still BSODs then there's something wrong with the hardware.
    • seanc
      • Nov 2008
      • 1319
      What service pack level is the CD you're using?
      Setting the BIOS to 'IDE mode' should kick things along.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        yeah 7b is usually a boot-time error. Disable Raid/AHCI
        hmm, maybe F6'ing and loading it from a floppy, also make sure you're loading the right driver. Also make sure its an SP3 disk
        • Wizard
          • Mar 2008
          • 2296
          SP2!? Okay I'll slipstream SP3. Where do I get this bagful of SP3 stuff?
          Don't these service pack don't get loaded eariler as this is 7B problem *with* during "booting" from install CD prior to the preparing hard drive stuff?
          I now have a USB floppy on hand now.
          And editing the BIOS settings on different mode of SATA or ATA didn't help.
          Cheers, Wizard
          • Spitz
            • Oct 2010
            • 95
            Originally posted by Wizard
            SP2!?
            Cheers, Wizard
            Try using a different cd drive. Sometimes it will make a difference.
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Did you disable RAID/AHCI?
              Ludicrous gibs!
              • Wizard
                • Mar 2008
                • 2296
                Actually none of above except one, the SATA AHCI, I set to SATA ATA for now and install driver then switch AHCI later. Regardless of this settings, the problem was USB bootable XP install. Funny this worked on other machines.
                I'm fixing up new CD with SP3 slip streamed. Now installing as I speak.
                Sigh!
                Cheers, Wizard
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  sometimes using a F6 boot driver from a USB floppy will not work with XP, it will take, then when it gets nearly done, it asks for the driver from a: and refuses it take it from the floppy, this is why I love vista/7's installer (only good thing about vista) is it can take a boot driver from anything (flash stick!), without even having to be a 'txtsetup.oem' install driver
                  if you have trouble, you can do a search for 'dell oem xp sp3 original torrent' or a varation on the such. there are tons of torrents out there of uncracked, original dists that don't come with a key or any pirate crap. Of course now a days you can use XP oem original and it will take an install on any dell/hp/toshy/gayway whatever, as long as you have the oem sticker on the bottom it can take it, with practically infinite activations too
                  • eppidrummer
                    • Jan 2011
                    • 65
                    Have you checked your ram? A lot of install errors are caused from a bad stick of ram.
                    • Wizard
                      • Mar 2008
                      • 2296
                      Like I said on post #8, I have solved the problem.
                      Cheers, Wizard
                      • NEWTEACH.
                        Dell optiplex 3090 micro device freeze problem
                        by NEWTEACH.
                        Hi im new tech please help me to remove absolute and device freeze
                        Optiplex 3090 micro
                        Service tag: CJHR0N3
                        Bios Chip: MX25L25673G
                        HERE IS MY BIOS BACKUP
                        Thank you in advance...
                        07-07-2025, 10:00 PM
                        DELL OptiPlex 3040m OptiPlex i5-6400T Specification for Upgrade or Repair
                        This specification for the DELL OptiPlex 3040m can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3040m boardview and OptiPlex 3040m schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        09-12-2024, 03:44 PM
                        DELL OptiPlex 5040 OptiPlex i5-6500 Specification for Upgrade or Repair
                        This specification for the DELL OptiPlex 5040 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 5040 boardview and OptiPlex 5040 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        DELL OptiPlex 3080 OptiPlex 3000 i5-10500 Specification for Upgrade or Repair
                        This specification for the DELL OptiPlex 3080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3080 boardview and OptiPlex 3080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                        DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                        This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
