Need advice for new computer
  • lti
    • May 2011
    • 2553
    I am looking for a low-end desktop computer to replace two of my old junkers. However, I do not know what CPU or how much RAM would be the best. I am looking to spend about $400 and want 64-bit Windows 7. I only need onboard video, and I already know to avoid Nvidia chipsets.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Need advice for new computer
    ddr3 is dirt cheap now a days. you can get a 2x2gb 1600 for a really good price
    go with an athlon II x2 or x4 with an amd chipset, gigabyte or MSI as long as it has all polymers or polymers and anything but kgz or ost
    look for rubycons or sanyo in the lower half of the board
    • lti
      • May 2011
      • 2553
      What about prebuilt computers? I won't save much money by building it myself, and there are too many things that can go wrong. It is hard to find a motherboard in this price range that has good caps.
      Why should I only look for those two brands of caps? What about Nichicon and Panasonic?
      • lti
        • May 2011
        • 2553
        How is this board? I noticed that all of the tiny caps are Teapos. Another Gigabyte board had Lelons in those positions.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          yeah pannys and nichis are too, but I haven't seen as many nichis lately on non-polymers
          if you're really saving that much with a pre-built, you're sacrificing quality
          if you don't mind not having a floppy or IDE port go with this one
          http://www.newegg.com/Product/Produc...82E16813130585
          its all pannys and sanyos, I don't think those smaller ones are even taepos or kgz's
          that with an Athlon II X2 245 through 260
          and http://www.newegg.com/Product/Produc...82E16820231277
          which I stand by ripjaws
          more then sufficient for win7 64
            master hoarder
            • May 2008
            • 12175
            Got a Micro Center near you??
            This is similar to the board that Uranium-235 posted:
            http://www.microcenter.com/single_pr...uct_id=0352421
            Pros: cheaper (after rebate), all solid caps, 4 memory slots (still maxes out at 16 GB though), eSata port
            cons: no pci-e 1x (there are 2 PCI slots, though)
            Processor - AMD Athlon II X2 255 :
            http://www.microcenter.com/single_pr...uct_id=0355993
            RAM - 4GB (2x 2GB):
            http://www.microcenter.com/single_pr...uct_id=0358348
            drives and all the rest - I'll let you pick those
            *EDIT*
            Oh yeah, need to look up a power supply as well - those are important too. No PowMax, I promise .
            • Wizard
              • Mar 2008
              • 2296
              Good time to snag the Dell Optiplex box if your CD is XP professional. They come with COA sticker on it. A used 745, 755, 780 series is between 200-300 range. And they do have good caps and poly capacitors.
              I picked up a 745 desktop (not tower) with 2GB in it, 80GB, no video card in it (onboard) for 180 canadian locally. Intended for my coworker.
              Also on Ebay you can get motherboard and CPU bundle for reasonable cost as long as you watch the price.
              minimum CPU: Pentium Dual Core to C2D range. The i5 is too high for your budget.
              DDR3 is good price right now, i got 4GB for 45 locally, by Mushkin, good memory maker.
              Asus 775 with intel chipset and Socket AM2/AM3 with AMD chipsets are poly caps these days. Even a MicroATX board wtih AM3 and AMD chipset/onboard 4xxx in it is very decent for a starter PC and put in a good low/mid end AMD video card later. This will get you around 300 or so for this kit if built yourself:
              AMD 800 series chipset Asus board around 100, Phenom X2 555 (3.2 GHz) goes for under 90 dollars or so.
              Decent PSU can be found on ebay too if you keep clear of branded version and go for OEM that was intended for branded computer like Delta, Bestec etc.
              Watch out that you do not get ripped by local stores, some charge higher prices and there is some good stores with reasonable price for good brands, are ones you seek out.
              Cheers, Wizard
                master hoarder
                • May 2008
                • 12175
                Well I was looking and looking and then I remembered that a number of members here recomended this power supply before:
                http://www.hypermicro.com/ProductDes...LY-BULK&key=it
                It's the famous 550W AcBel Polytech. On sale for $15.
                Also found these on hypermicro while looking for the above beast:
                400W, looks like Delta, with 30A combined on the 12v rail, no APFC though (PPFC perhaps?)
                Sparke/SPI (FSP group), 650W, with APFC
                http://www.hypermicro.com/ProductDes...-SUPPLY&key=it
                I'll wait for other members to approve of these units, though. Most of them should be OEMs from known companies as Wizard mentioned. Definitely more than enough for a basic system, too.
                • Wizard
                  • Mar 2008
                  • 2296
                  Even 300W-350W is plenty for most.
                  Cheers, Wizard
                  • brethin
                    • Dec 2008
                    • 1907
                    I may have a Dell XPS 410 with a Core 2 Duo, 3 gig ram, Windows 7 Ultimate, if your looking for something around $250.00
                    • lti
                      • May 2011
                      • 2553
                      I was hoping to save money by using an IDE hard drive that I already have. I just noticed that the board I posted doesn't have IDE connectors. I should just buy a new hard drive.
                      I don't know of any stores near me that sell computer parts. They sell crappy prebuilt computers like Compaqs, and most of them have Nvidia chipsets and huge hard drives that I have no need for. The best I saw was a Lenovo with 3GB of RAM and KZG caps. Any computers with more than 3GB of RAM have 1TB or larger hard drives, which significantly increases the cost of the system. My current computer has a 60GB hard drive, and I only have a few gigabytes of files.
                      I have software that will not run under Windows XP. I need 64-bit Windows 7.
                      Is there a reason for buying 2x2GB RAM kits instead of a single 4GB stick?
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Dual-channel memory. Performs better if 2 or 4 slots are populated, vs 1 or 3.
                        Ludicrous gibs!
                        • lti
                          • May 2011
                          • 2553
                          Would I actually notice the performance increase?
                          • brethin
                            • Dec 2008
                            • 1907
                            No
                            • brethin
                              • Dec 2008
                              • 1907
                              I also have a MPC Clientpro 385 with a Duo core 2 cpu, 2 gig of ram, Win 7 Ult and will let you use your IDE drive, I can part with for around $200. Fill in you location on your profile so I know where you and can make get a guess on shipping costs.
                                master hoarder
                                • May 2008
                                • 12175
                                If you are getting a new computer, might as well get new hard drive too. Just like you, I don't have a use for those big hard drives either, but they are much faster than your old 60 GB and you will notice the difference. Both your OS and you programs will load much faster. They aren't all that expensive either. You can grab a 320 GB Western Dig. Caviar Blue for $32 or so.
                                Also, I just got the regular Micro Center email yesterday. They have the AMD bundle again, and some of the motherboards are free with this bundle. See this page:
                                http://www.microcenter.com/specials/...ource=ACT_BYO&
                                Basically, you can grab a Phenom II X2 560 for $90 and get this motherboard free:
                                http://www.microcenter.com/single_pr...uct_id=0350746
                                Or get the same processor with this motherboard for $100:
                                http://www.microcenter.com/single_pr...uct_id=0361911
                                An extra $10 will get you a Phenom II X4 840 quad-core.
                                I think any of these should have you set for quite a few years.
                                • lti
                                  • May 2011
                                  • 2553
                                  I'm not reusing the drive that is in my computer now, but the drive I was planning on using is a Western Digital 60GB ATA100. Would a new drive really be that much faster?
                                  If I build the computer, I would use the Gigabyte board I posted above, an Athlon II X2 250 CPU, a single 4GB stick of RAM, and a 250GB Western Digital hard drive. I would prefer to purchase a computer from a store, but any local stores only sell high-end components that are out of my price range or "media center" computers that have almost no hope of doing anything resembling work.
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    RAM - 4GB (2x 2GB):
                                    *EDIT*
                                    there is a x1 slot to the left of the northbridge
                                    why not get 2x2? The only reason to get a single 4gb stick would be if you only have 2 memory slots, and can only afford 1 4gb stick, and you want to upgrade to 8gb later (64-bit OS required)
                                    that motherboard ^ he posted has 4 slots, so you can get 2x2gb now, and get 2 more 2gb later for total of 8gb dual channel
                                    • lti
                                      • May 2011
                                      • 2553
                                      You seem to think that 8GB is the most RAM anybody will ever need. Why can't I have two 4GB sticks for 8GB in dual channel mode?
                                      All of the boards I have been considering only have two RAM slots.
                                      If I have to spend that much to get four RAM slots, I would like an AM3+ board.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        you said in the last post you would get a single 4gb
                                        I think 16gb is excessive. I have 12 and I play every game under the sun and have never gone over 4gb of usage
                                        • Borse2008
                                          by Borse2008
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Green Probe
                                          Mosfet Advice
                                          by Green Probe
                                          Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                                          05-22-2025, 10:49 AM
                                        • user234
                                          Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                                          by user234
                                          Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                                          My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                                          I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                                          If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                                          This is...
                                          05-10-2025, 04:25 AM
                                        • artvandalai
                                          Advice on rewiring this stepup transformer?
                                          by artvandalai
                                          I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
                                          01-14-2025, 01:00 AM
                                        • wattsRpower
                                          MBP 820-00928a need advice
                                          by wattsRpower
                                          I'm working on an a1707 macbook pro for a friend of mine that said it had stopped working and will not turn back on. After opening up the laptop I discovered a short on C7382 which took the PPBUS_HS_CPU to gorund.
                                          After fixing the cap issue, I had 12.6 volts on the line. Not sure what or when something happened, but I am now getting 3.6 to 3.8 volts fluctuating. I was taking some volt readings and I'm not sure if I shorted something or if something else has happened.
                                          At this point, I'm not sure where to start looking for something to fix. Maybe the cpu fried anyway when the PPBUS_HS_CPU...
                                          10-12-2024, 04:55 PM
