CEB703 replacement
  • Smiffy
    • Feb 2006
    • 16
    CEB703 replacement
    Hi All
    I had a nice accident with a naff old ECS board.I overclocked a tualatin 1.3Ghz to 1.73Ghz but i think the current strain was to much for the regs and a CEB703(30v 40A) let go in a puff of smoke.As the cpu amazingly still works can I upgrade the CEB703s on my other two boards to something beefier,say FDB7030L.(30v 100A)
    Thanks for any info
    Smiffy
  • Rainbow
    • Aug 2005
    • 1374
    Re: CEB703 replacement
    I've replaced burnt mosfets on many boards - sometimes with better replacements. Not only the current rating but also Rds(on) matters - the smaller Rds(on), the cooler will the mosfet run.
    • Smiffy
      • Feb 2006
      • 16
      Hi Rainbow
      Ta for advice
      RDs(on) on for the 703AL is 17 milli ohms at Vgs=10v and 30 milli ohms at Vgs 4.5v
      On the 7030 it is 7 milli ohm at Vgs 10v and 10 milli ohm at Vgs 5v
      Smiffy
      • Rainbow
        • Aug 2005
        • 1374
        If both are logic-level mosfets, then it should work fine.
        Once I used non-logic level mosfet as an replacement. It worked the board had power-up problems with some CPUs. So I replaced them with logic-level ones later and it worked fine then.
        • Smiffy
          • Feb 2006
          • 16
          Hi Rainbow
          Yes it is Logic level.Having trouble sourcing it though so may have to look at something else.
          Smiffy
          • MD Willington
            • Sep 2004
            • 702
            I take it you've also checked the caps? If you're going to dig into it, best to do the whole show.
            Cheers.
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • Smiffy
              • Feb 2006
              • 16
              Hi
              HAve checked them all,no pops or bulges but have enough Panasonic FCs and Rubycon ZLs lying around to change them all anyway.Hoping STB80NF03L mosfets woould be ok.80 Amp with Rds(on)0.004 ohms but dont know if its logic level compatible.Smiffy
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                STMicroelectronics' datasheet calls it a "Low threshold drive" part.
                PeteS in CA
                • Smiffy
                  • Feb 2006
                  • 16
                  Hiya PeteS
                  That should be ok then.Will heatsink them up.I can only conclude the originals cop it because the processor wants more amps that they can supply.
                  Smiffy
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • ezenia
                    PS4 controller left stick potentiometer replacement issue
                    by ezenia
                    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                    09-30-2023, 02:19 PM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
                  • r2digital
                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                    by r2digital
                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                    04-18-2024, 03:50 PM
