Re: Dell used to be really good quality....
Forget what I said about HNs. They cost too much. How about KYs? They are like $0.50...pretty tempting. Thanks.
Say I used HNs for the caps that need to be low-ESR, would that work? They also have good specs. High ripple current/low ESR.Leave a comment:
Using used caps is a risk I take.Leave a comment:
Good to know, thanks ! I have repaired stuff with used capacitors with no problem though. I'll make a search.Leave a comment:
Make sure you search the forums for some of the pitfalls of reusing used capacitors. It's not always a good idea as capacitors reform to the voltage of the circuit they are on. For 12 year old used capacitors, I wouldn't even consider it...Even reliable caps have a finite life.Leave a comment:
Same for Acer, which doesn't have a great reputation in terms of durability of their hardware. I've found the remains of an Acer eMachines from 2008, and to my surprise, the processor (IIRC) capacitors on the motherboard are all Sanyo ! I did the same and removed the capsLeave a comment:
the number on the post counter (at the right.. where it says #87, #88, #89, ...) is actually a link to view a single post.
like so
https://www.badcaps.net/forum/showpo...7&postcount=88Leave a comment:
What goodpsusearch said is usually the case but it's best just to look up the specs on the old ones because PSU's do have ringers now and then just like mobos.
[ringer = non-typical & unexpected value]
Also mfr#1 might use one great spec cap where mfr#2 uses a pair of lesser caps in parallel to achieve the same thing.
It's just better to look them up.
.Leave a comment:
FM, FR -- [.030][.018-.019] and below...Leave a comment:
Great list, but which are suitable for power supply use?Leave a comment:
like so
Very nice! Bookmarked.Leave a comment:
UG!
I really need to put up a web page on this so I can link to it instead of writing it out every time..
The tiers go:
[xxx][xxx] = ESR(or ESR range) at [8x20mm][10x20mm]
HZ, GA -- [.009][.007]
KZJ, GC, HN, MCZ -- [.012][.010-.011]
FJ, FL, WGL2, NRSJ -- [.016][.013]
MBZ, HM, WG, GD, KZG, NRSK -- [.018-.019][.013]
KZG, ZLG -- [.020-.021][.013-.014]
GE -- [.025][.016]
HV, ZLH, KZM, KZH, NRSH -- [.029-.033][.019-.020]
ZL, KZE, WX, HD, GK, NRSG -- [.041][.023]
ZT (125C - Low ESR & High Temp) -- [.054][.030]
PA, FK -- [.044][.035]
HE, KY, YXG, YXH -- [.069][.046]
JXA, FC, PW, NRSX, NRSZ, and others --[.065-.080][.044-.054]
LXZ, PM, and many others... - [.080-up]-and-[.050-up]
There are a few not included because they are newer than when I made this or I simply had a brain fart.
The ones that are in bold are simply the ones seen most often and/or that usually come up in conversations.
.Last edited by PCBONEZ; 03-29-2011, 12:11 AM.Leave a comment:
Yes
Caps like FC, PW, LXZ are 'entry level' low ESR caps.
They ARE low ESR but not drastically low ESR.
The benefit to using them in place of GP is they are usually higher quality caps.
Also, since you aren't buying GP + [like "FC grade"] caps you can take advantage of the qty discounts. [Buying one kind for both applications.]
An example is 220uF 16v. They are used like EVERYWHERE and it's a mix of GP and 'entry level' low ESR.
Rather than stocking two kinds of 220uF 16v caps I buy 'entry level' low ESR 100pc [or more] at a time which cuts the cost per-each significantly.
I've been looking around...and is it just me, or do FMs absolutely destroy other caps spec-wise? I'm looking at Nichicon PMs/ UCC KY among others. Seriously FM is like off the charts. Comparing exact case size and values. ESR is almost half as low, and ripple current is doubled in some cases. The only competitor I see is UCC KZE which looks pretty darn decent as well.Last edited by TheLaw; 03-28-2011, 06:57 PM.Leave a comment:
I'd love to fix it but i don't see anything looking bad.
Anybody?Leave a comment:
.Leave a comment:
I'll take that as a yes.Leave a comment:
Impedance wise, that's okay? To use pretty low ESR caps in place of even the General Purpose?Leave a comment:
This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:44 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:44 PM
This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:36 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:36 PM
This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...09-12-2024, 03:30 PM
- Loading...
