Dell used to be really good quality....
  • ratdude747
    replied
    Re: Dell used to be really good quality....
    Originally posted by ncovert
    You know, the Dell Dim4600 uses DDR RAM not PC4200
    sounds like a typo to me
    in common usage, yhere are 3 speeds off DDR:
    266mhz (PC2100)
    333mhz (PC2700)
    400mhz (PC3200).
    the dimension will do any of those; my mom's uses 4 PC3200 512mb sticks and runs just fine... once you fix/replace the PSU, the 4600 is actually not a bad little computer.
  • RJARRRPCGP
    replied
    Originally posted by seanc
    The Vostro 200 series are all cheap and nasty
    They seem fine to me. One that was given to me works good. Looks typical to me.
    I cannot say that they're flat out cheap-and-nasty.
    And the Inspiron 530S is related, looks like it's just a year-newer version of the Vostro 200.
  • ncovert
    replied
  • TheLaw
    replied
    Got home today expecting to see a Mouser box in my door. Checked the tracking. Departed from Fortworth Texas 4/6/11 (today) @ 4:48PM...wtf. Ordered on Monday. =P
  • PCBONEZ
    replied
    They [Dell] seems to on mobos but they seem to ignore it in PSUs.
    Dell GX270 boards were labeled Intel up until the bad HM/HN fiasco where GX270 were blowing caps right and left,,, then suddenly those boards said Foxconn,,, they were the same boards otherwise.
  • TheLaw
    replied
    Originally posted by PCBONEZ
    Dell doesn't build their own stuff, they OEM.
    Their mobos are from Intel [who sometimes outsources to Foxconn].
    Their PSUs can be from a number of different companies - even in the same Dell model.
    I think they have a little bit control over the general quality of the machine. Like whether they want OSTs or Rubycons. Could be making things up again.
  • TheLaw
    replied
    I think Intel is exclusively Foxconn these days. I haven't see an Intel board made by any other OEM in a while.
  • PCBONEZ
    replied
  • TheLaw
    replied
    Kind of like my Optiplex. OSCONs and Chemi-Cons on the board and the power supply is G-Luxon.
  • Uranium-235
    replied
    got a vostro 200 desktop tonigh (windows fix)
    dell got it right, use rubycons! but wait, every cap is a rubycon...except vrm...all kgz, and vrm for ram too
    but all the smaller-medium caps are ALL rubycon
    fail
  • TheLaw
    replied
    We'll see how it goes.
  • PCBONEZ
    replied
    Sounds like a good plan.
  • TheLaw
    replied
    I bought FCs for the low-ESR, some FCs for the "GP" as well as some PWs and one PJ.
  • PCBONEZ
    replied
    Should still have low ESR in the PSU. - Especially the OP filters.
  • mockingbird
    replied
    PCBONEZ, keep in mind his computer is an old socket370 coppermine...
  • TheLaw
    replied
    It all comes down to bean counters.
    I'll try to take everything you've told me into consideration. I'm seriously trying. Thanks.
  • PCBONEZ
    replied
    That was explained too.
    When you have a GP cap go by just the ripple.
    Using a GP cap with at least that much ripple is fine.
    Using an entry level low ESR cap [with at least that much ripple] is fine and usually better because low ESR caps are usually better quality than GP.
    -THAT- GP cap though should not have been a GP cap to start with.
    Someone was 'costing down' a bit too much that time.
    [PSU probably had lots of noise in the output.]
    I suppose it's possible it was recapped sometime in the past using crappy caps.
    But:
    If it at least ran with a GP cap there then any entry level Low ESR cap would be an improvement.
  • TheLaw
    replied
    You aren't expected to know what you are doing yet.
    You do need to be more clear as to specifically what you are asking about.
    https://www.badcaps.net/forum/showpo...7&postcount=88
    WHAT "the 16v" - you've asked about more than one cap.
    [Starting a thread for each project would help with that.]
    -- If you want 'specific' answers you need to ask 'specific' questions.
    -- Otherwise you get a general answer.
    And, you keep asking the same questions over and over which gets annoying. For example you've asked what to use for this same G-Luxon 2200uF 16v HM several times spread over more than a week. It's getting old..
    Lacking tone of voice:
    - This is intended as -constructive criticism-.
    - If I can get you to ask better questions then it's easier for us to help and you won't be chasing your tail so much because the answers from different people will be more consistent.
    I've never fixed a power supply before and there is an element of uncertainty to a first time you do something. The reason I asked about the 2200uF 16V so much is because a.) I originally was going to use a 10mm form factor, b.) then I decided 12.5mm was going to fit. c.) there was no ESR listing in the G-Lux datasheet, so how am I supposed to know which to use? d.) I was confused as to how low you could go in ESR, or if you should stray.
    There were reasons why I asked so much, but I'll forget about it now. It's over. Thanks to all who had to "deal with me". I'm sorry it was that painful for you.
  • TheLaw
    replied
    As is shown in the earlier post
    [and previously discussed] PW -IS- a low ESR cap comparable to FC, both of which are on the low end of low ESR but they are still low ESR caps. In fact both of those are highly regarded series' of caps.
    And, as was already said several times by several people..
    You can use entry level low ESR caps in place GP caps just fine.
    Amazingly...
    Good brand entry level low ESR caps are good to replace bad brand entry level low ESR caps too.
    Well thanks PCBONEZ (and everyone else). I'm sorry if if bugged you out...for over a week. I'll order em and recap, make a new thread, and put some pictures up for reference (assuming it works).
  • PCBONEZ
    replied
    Originally posted by TheLaw
    Well perhaps I am not as competent in this subject as all of you seem to be. I'm sorry for seeming ignorant. I read spec sheets. I make a judgement. I ask you guys for confirmation, but I guess I don't know exactly how to "ask" correctly.
    And it's not completely out of the blue...
    Thanks for the info.
    DELL Vostro 3670 Vostro 3600 i3-8100 Specification for Upgrade or Repair
    This specification for the DELL Vostro 3670 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3670 boardview and Vostro 3670 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
    09-12-2024, 03:44 PM
    DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
    This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
    09-12-2024, 03:36 PM
    09-12-2024, 03:30 PM
