So what do you say - Which is better in framerate performance terms? Both are for AGP bus.
7950GT vs HD3650
7950GT vs HD3650
Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Tags: None -
Re: 7950GT vs HD3650
Probably the 7950GT. The HD3650 is similar in performance to the 7600 series.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro -
So to my opinion it is somewhat same/slightly better than the N7800, definitely not the 7600series...just to tell, anyways thanks for your opinions.Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.Comment
by JohoHi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
Model: HP ProDesk 600 G2 Desktop Mini
Product No: Y3J22EC#ABD
BID=15WWP3ET6**#SABD#DABD
Serial: CZC632BBCJ
First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
Without CPU I get "CPU...03-07-2025, 09:18 AM -
by mostachioHi Badcaps,
I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
TV Details:
Model # - TH-65DX700Z
Symptoms:
The television turns on and displays a picture then makes a clicking sound and turns off.
I haven't opened it up yet but... -
by kazzekI came across some technical terms that are used to describe some capacitor types, mostly in the US. I was wondering what axialytic rabro and radialytic rabro mean? I can guess that axialytic is perhaps a combination of words axial and electrolytic. The same applies to radialytic. What does rabro mean?
by harpsimple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
Channel: Troubleshooting & Designing Networks
by DrvLikHellHello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
The... - Loading...
