Intel 2.0 GHz processor running at about 200Mhz? Help
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Intel 2.0 GHz processor running at about 200Mhz? Help
    Originally posted by PCBONEZ
    It's rare but if the heat pipe leaks it's gas out it will lose most of it's heat transfer capabilities.
    I've seen this happen, but only once so far. That was indicated by a constant high fan speed, though. Once I disassembled it, I realised that the CPU block was getting hot, but the heatsink at the end was not...
    Ludicrous gibs!
    • coolcurrent
      • Oct 2010
      • 98
      Yes it does. In real time.
      i have downloaded CPU-Z and used it on my system.
      the processor speed fluctuates between 1999MHz to 2002MHz
      The FSB speed fluctuates between 404MHz to 200MHz
      I have also attached the report CPU-Z generated, check if you can find any errors.
      besides if this indicate the processor is working fine, might it be a driver issue because i just formated the laptop?
      if its driver issue, from the zipped text report i attach can you point me to the right drivers?
      i initially downloaded drivers from samsungpc.com, but the scenario lingers
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Gotta be a bug in CPU-Z with the 404MHz thing. The FSB is 200MHz, what it's supposed to be. Nothing funky in the report. Grab this piece of software. If the red throttle indicator fluctuates, then there's something wrong with the cooling.
        A working TV? How boring!
        • mockingbird
          • Dec 2008
          • 5488
          The P4 only had a 400Mhz FSB in the abstract:
          Notable with the introduction of the Pentium 4 was the 400 MHz FSB. It actually operated at 100 MHz but the FSB was quad-pumped, meaning that the maximum transfer rate was four times the base clock of the bus, so it was considered to run at 400 MHz.
          I think when CPU-Z is showing 200MHZ, it's showing 50Mhz * 4 FSB and when it's showing 400, it's showing 100Mhz * 4, so it does sound like a throttling issue, not a bug.
          Why the *actual* cpu speed is not going down, that's a good question. But the FSB fluctuation is pretty indicative.
          • coolcurrent
            • Oct 2010
            • 98
            there isn;t any red indicator, instead it green CPU load indicator and graph. is this what you where referring to
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #26
              @ mockingbird: CPU-Z shows both "real" (clock rate) and "rated" (data transfer speed) FSB.
              @ coolcurrent: That's strange if the throttling indicator doesn't show. It means throttling is either custom managed or disabled entirely (in which case it should have crashed, which it doesn't). Try temperature reporting programs such as Everest (go under Computer->Sensor) or SpeedFan, i recall that's what i was using when i had a P4. Any temps past 60C are signs of worry, Northwood processors start throttling at 63C.
              • mockingbird
                • Dec 2008
                • 5488
                #27
                You mean to say that CPU-Z *should* show real clock rate. But it's not. Wouldn't FSB fluctuation indeed indicate throttling? Doesn't CPUz only rely on ACPI tables to record information? Who says Samsung's bios isn't fooling it?
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  #28
                  This never disappointed me.
                  • coolcurrent
                    • Oct 2010
                    • 98
                    #29
                    The throttling sub menu is simply disabled under the view menu. what next now?
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #30
                      As i said, check the temperature.
                      • coolcurrent
                        • Oct 2010
                        • 98
                        #31
                        i just confirm that this system does not have any internal temperature monitoring device, except for that of the harddrive
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          #32
                          It does have temperature sensors, they have to control it somehow. But they're not exposed to the user, shame on them.
                          Buy a multimeter with a temperature probe, it should only set you back $15 and you'll find plenty of use for it. Stick the temperature probe into the heatsink and try to make it reach the center. See what you get.
                          • mockingbird
                            • Dec 2008
                            • 5488
                            #33
                            Temperature is always available via the ACPI table. You just need a utility to access it. In Linux you would find it under /proc/acpi, you would just issue cat /proc/acpi/cpu or something like that, after setting up lm_sensors.
                            In Windows, there's an old utility called "Motherboard Monitor" that might work.
                            • Rulycat
                              • Apr 2010
                              • 724
                              • United Kingdom
                              #34
                              Speedfan may work.
                              • coolcurrent
                                • Oct 2010
                                • 98
                                #35
                                Originally posted by top_cat
                                Speedfan may work.
                                i hav tried speed fan, and can't get any temperature monitoring.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 5096
                                  • New Zealand
                                  #36
                                  Really? My Toshiba Satellite P35 has nothing in the way of temperature reading. I have tried multiple programs in Windows and lm_sensors etc in Linux, and I get nothing, just the Hard drive temperature.
                                  -David VanHorn
                                  • mockingbird
                                    • Dec 2008
                                    • 5488
                                    #37
                                    You have two seperate issues.
                                    I know, because I also have a Toshiba laptop with the Phoenix bios.
                                    Firstly, you need to fix your DSDT table. See my instructions here at the Ubuntu forums:
                                    http://ubuntuforums.org/showthread.p...036051&page=52
                                    Skip to step 8, if you get the problem that I describe at the beginning of the post, then start over at step 1.
                                    The other problem I found after recompiling my DSDT table was that I was still not getting thermal_zone and throttling registering in /acpi. But I have heard that this can be caused by two things. Firstly, using x64 Ubuntu, secondly, having "thermal" compiled as a module.
                                    I am going to try to recompile the kernel, this time with "thermal" in it, and I'll see if that fixes it, otherwise, I'll see if the i386 version does anything. If not, then it's Toshiba's problem and I will never touch their laptops again.
                                    If you have troubles fixing your dsdt table, then post the file, I will give it a go. But don't forget that you'll still have to recompile your kernel to use a custom DSDT.
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 5096
                                      • New Zealand
                                      #38
                                      So as not to hijack this thread I have posted separately here: https://www.badcaps.net/forum/showthread.php?p=142876
                                      -David VanHorn
                                      • mockingbird
                                        • Dec 2008
                                        • 5488
                                        #39
                                        Ok, let me look at your errors and see what I can find.
