replacements for Teapo caps
  • pflowers
    • Jan 2009
    • 36
    hey there, I am replacing some caps on a mobo the old caps are
    Teapo SC
    1000uf 6.3v
    8mm x 11mm
    Teapo SZ
    1500uf 6.3v
    8mm x 20mm
    I was wondering if these are good replacements
    Nichon HM
    1500uf 6.3v
    Panasonic M
    1000uf 6.3v
    the Pan M serries I found at Digikey but it didn't list ESR or Z ratings and the temp is -40 ~ 105 as opposed to the teapo -40 ~ 105, but it was the only one I saw with a high enough ripple
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: replacements for Teapo caps
    AFAIK the Nichicon HM are known faulty series. Only the ones made in 2005 were bad but you don't know what lot they are from before you get them, so best pick something else.
    A working TV? How boring!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      ~ NO ~
      The HM and HN made from 2001-2004 were bad.
      Problem was announced publicly by Nichicon in mid 2004.
      Problem fixed in 2004 but exact date unknown.
      2005 and newer are good but some people are afraid of 2005 dates.
      Mann-Made Global Warming.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Here are the specs.
        - Dr Seuss
        • seanc
          • Nov 2008
          • 1319
          I've encountered failed 2005 HMs in an Optiplex SX280 - which was probably due to that machine being hot, but I swapped them out for new ones anyway.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            A failed HM in a heater box that readily fries MBZ, MCZ, FL & FJ as well doesn't prove anything.
            If 2005 HM/HN scare you then don't use them and save some hair.
            - But there isn't anything wrong with them.
            The only bad HM w/date codes 2005 up I've heard of came from heater boxes or had a bad PSU involved or the PSU wasn't checked at all.
            - AND I ask EVERY time it comes up. [Because I have some in service.]
            I have yet to see a case where 2005 HM or HN were -confirmed- as 'just went bad on their own'.
            The ones I have in use are on an Itox board in a file server and it has been running pretty near 24/7 for 3+ years now and not a problem.
            Besides, HM are probably coming from Mouser who would not have 2005 HM or HN caps anyway.
            - In 2005 they weren't stocking HM or HN.
            They dropped the product line for a few years after Nichicon's announcement in 2004.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Teapo SC
              1000uf 6.3v
              8mm x 11mm
              Teapo SZ
              1500uf 6.3v
              8mm x 20mm
              Nichon HM
              1500uf 6.3v
              Panasonic M
              1000uf 6.3v
              The SZ is comparable to MBZ and yes, HM is good.
              The panny M are probably fine for the SC but I'd go better.
              Possibilities are
              Chemicon LXZ 6.3v 1000uF or 1000uF 10v FC.
              [The 6.3v 1000uF FC is 10mm, use the 10v for 8mm.]
              Note:
              - The SC specs are given at 120Hz @25C. 'In theory', the Ripple at 100kHz would be around 632 mA if Teapo's multiplier is correct.
              - The 'M' specs are given at 120Hz @20C so you can't compare exactly without some math.
              - Dr Seuss
              • pflowers
                • Jan 2009
                • 36
                Thanks for the input.....I remember all that buzz on the HM....had forgotten about that....but I think I will use it anyhow.....that LXZ 6.3v is 15mm in L and a little pricey, but I have the clearance and its not my .64 cents...
                sorry to have caused such a disturbance and thank you once again for solid advice
                Paul
                  by momaka
                  03-12-2025, 03:42 PM
                • SluggerB
                  Can't find exact matching caps for replacements, what should I get to prevent video issues?
                  by SluggerB
                  I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                  I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                  The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                  04-05-2024, 07:47 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • ziplock
                  Abit BE6-II motherboard
                  by ziplock
                  Greetings,
                  I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
                  I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
                  04-20-2025, 02:09 PM
