SCSI termination -D'OH
  • bigbeark
    • Jan 2010
    • 661
    Well, that problem I was having with SCSI adapters not detecting the drive was a classic
    newbie blunder on my part. I did not have a terminator on the cable, put one on and bingo
    the drive was detected.
    Does it matter if the drive is between the card and the terminator? I see that there are these terminators that attach to the output SCSI connector (ie on the back of the case).
  • Wizard
    • Mar 2008
    • 2296
    Re: SCSI termination -D'OH
    1. Good SCSI drives should have terminator built in, enable or disable accordingly. And many older drives use resistor packs, (old times) easier to leave them unterminated and put them between the terminated SCSI bus.
    2. Golden rule: always terminate the ENDS of the SCSI bus. Anything in between left unterminated. Even use a SCSI drive with terminator enabled at the one end. The controller card should have their terminator enabled or disabled and use the cable ends terminated. Flexible.
    FYI: SCSI technology is a bus.
    Cheers, Wizard
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      lvd drives must be terminated on the backplane or cable.no on drive termination.
      Cheers, Wizard
      • NxB
        • Feb 2009
        • 1595
        The only SCSI I've seen on recent hardware is LVD. Everything else is FC or SAS.
        • japlytic
          • Oct 2005
          • 2086
          When it comes to SCSI terminators and drives, even one SE device or terminator on an LVD bus can cause all devices to operate in SE mode, most likely with lower performance.
          The only terminators I would recommend are active ones, and FPT terminators are recommended in high noise environments.
          • douglasfir
            SCSI controller problem
            by douglasfir
            Hi there! I have an Adaptec 2940w/uw 50/68 pin controller card in an old machine I'm trying to set up, and i'm having a problem getting the drive to even spin up when it connected to the controller. The drive will spin up with the cable connected to it and not the controller. But not when it's connected to the controller. The drive is a seagate st336607lw u320 10k RPM. The cable is an SE/LVD 68 pin with a terminator on one end. Scsi controller is set to defaults. I have enabled termination power with the jumpers on the drive itself. The drive is connected to the last connector before the terminator...
            08-10-2019, 10:47 AM
          • bigbeark
            SCSI Termination
            by bigbeark
            Any SCSI experts here? I am using an ASUS CUR-DLS with onboard LSI SCSI and Ubuntu Linux. I was using a Seagate Cheetah ST##^&52LC Drive until it got too hot. I am now using an IBM drive whih I am pretty sure is a quantum/maxtor - cool running but not as quiet as the Seagate. Ubuntu Logs shows:
            6.518136] scsi target3:0:0: FAST-80 WIDE SCSI 160.0 MB/s DT (12.5 ns, offset 62)
            Apr 18 15:05:31 barry-desktop kernel: [ 6.523632] scsi target3:0:0: Ending Domain Validation
            I use a SCA adapter which has a small resistor on it and two pins marked TRM PWR . I am...
            04-18-2010, 08:20 PM
          • bilux
            uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
            by bilux
            I want to find a replacement for uP0109 8pins, and i found this parts:
            uP0109 is "2A Ultra Low Dropout Linear Regulator"
            RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
            FP6137C is "2A BUS TERMINATION REGULATOR"
            can replace uP0109​ by RT9199 or FP6137C ?
            11-01-2024, 12:00 PM
          • Balamanas
            Dell Vostro 3525 AMD Radeon HDL5D LA-L945P bios
            by Balamanas
            Hello. A process was forcibly terminated during the BIOS update. Corrupted BIOS. Maybe you could help create a good bios file. Dell Vostro 3525. Ryzen 5, AMD Radeon. HDL5D LA-L945P Rev. 1.0 (A00). TAG - 8XLF5R3 . I am attaching the corrupted file. Thank you very much....
            04-08-2025, 02:02 AM
          • TechGeek
            Power Macintosh 7200/120 PC Compatible Restoration
            by TechGeek
            So here we go. The system featured here is a Power Macintosh 7200/120 computer with a PowerPC 601 CPU and 24MB of RAM. It was built sometime in 1996 and appears to have been in use between 1997 and 2007, with most activity ceasing by 2005.
            The system was also ordered with the PC Compatible option, which, in this case, is a 12" long PCI card with an entire PC compatible system on it. It has a 100MHz Pentium (i586) CPU, 8MB or 16MB of onboard RAM, an ATi Mach/64 video card, and a Sound Blaster Vibra16 sound subsystem.
            It was checked into a computer repair shop (presumably...
            03-21-2023, 03:23 PM
