SCSI controller problem
  • douglasfir
    • Oct 2018
    • 6
    Hi there! I have an Adaptec 2940w/uw 50/68 pin controller card in an old machine I'm trying to set up, and i'm having a problem getting the drive to even spin up when it connected to the controller. The drive will spin up with the cable connected to it and not the controller. But not when it's connected to the controller. The drive is a seagate st336607lw u320 10k RPM. The cable is an SE/LVD 68 pin with a terminator on one end. Scsi controller is set to defaults. I have enabled termination power with the jumpers on the drive itself. The drive is connected to the last connector before the terminator as it should be. No other scsi devices on the bus. Drive is set to scsi ID 0. Controller ID 7. I've downloaded the pdf for the drive and gone through it extensively, and cannot get the drive to start when connected to the controller. I know the drive will not operate at u320 speeds on this controller, but from what I've read it is compatible. The scsi bios returns an error of "termination not detected" and obviously does not detect the drive. I've used scsi before, and I've never had this problem. I have an identical controller and two other drives and everything behaves the same with the other drives and controller. The only thing I don't have is another cable. The pins are not bent, and there don't appear to be any damaged wires on the cable itself. This is driving me nuts. Please help. What could I be missing? Thanks for your time!
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: SCSI controller problem
    Are you saying the other drives/controller/cable work properly? Or, exhibit the same sort of failure? Obviously, moving the current disk over to the other controller would be an easy test. Or, moving one of the other drives/cables over to this controller. On the SUT, remove any superfluous SCSI devices so you're POSITIVE there isn't a conflict.
    Double-check the "termination" setting in the HBA BIOS. Different Adaptec HBAs treat termination "errors" differently (e.g., some of the adapters will hang if left unterminated) and even different BIOS versions on a single HBA model. IIRC, the termination check is just done by examining the open circuit voltage on the interface (Looking for the Vt equivalent from the termination network).
    To simplify things, be sure you're not mixing narrow and wide devices. If there are THREE bus connections on that model cad, you can only use TWO of them at the same time (bur ONE is the safest bet).
    There's also a setting for the HBA to send a START_UNIT command to each specific SCSI ID -- make sure your SCSI ID is set for that (else you'll have to wait for the OS to issue the command).
    The SCSISelect utility will let you try to issue commands to the drive without having the OS stick its nose into the process.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      That is a very old controller. Make sure it's got the latest firmware on it. What drive specifically? Check the drive jumpers and make sure drive spinup delay is off. Depending on the drive, this may also be called 'start cmd' or 'motor start delay'....or something along those lines. With this off, the drive will spinup when powered up whether its connected to the controller or not. If the drive still fails to spin up, odds are the drive is bad.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • douglasfir
        • Oct 2018
        • 6
        Thanks for replying! When I move the drives/cable over to the other controller (identical 2490w/uw) the same failure is produced. There are no other SCSI devices on this bus whatsoever, im only connecting one drive at a time. I will check the SCSI bios for the send start unit command. Thanks so much, i'll let you know how it works out. I'm out of ideas otherwise.
          • 31200
          turn off the drive termination if the cable is terminated.
          latest card firmware is 4.something.
          what other jumpers are on the drive?
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            There won't be any terminations on the drive -- though there may be a TERMPWR option available. And, maybe even an option to convert between LVD and SE signaling.
            As that HBA is designed with the ability to drive from the center of the SCSI bus (both ends of the bus must be terminated), if there are no internal nodes, then the HBA's terminator must be enabled (HIGH and LOW bytes) if there are no internal devices to provide the termination.
            Some drives will delay their spinup by a time related to their SCSI ID (staggered spinup to ease demands on power supplies) -- usually something like 6 seconds per SCSI ID (so, if you want a single drive to spin up sooner instead of later, pick a low SCSI ID).
            Jumpers are typically only examined on power-up so cycle power for any changes to be noticed.
            The fact that the drive DOES spin up suggests it is expecting to be told to do so when connected.
              • 31200
              well spinup needs to be checked in the card settings.
              i was doing some of this yesterday, but not with Adaptec, their bios's are junk and even assign the wrong interupts.
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                Drives typically have straps to allow:
                - unconditional spinup
                - wait for START UNIT
                - spinup after delay (usually based on SCSI ID)
                A drive configured to unconditionally spin up will usually do so even in the presence of a START UNIT command. OTOH, a drive that is strapped to wait for START UNIT will usually just sit there until/unless it gets one!
                I don't, however, know if the behavior will vary depending on whether or not the drive is free-standing (I only spin up drives that are tethered to an HBA). That's the sticky point in the OP's description of symptoms (does the drive know/care that it is free-standing or not?)
                Swap drive/cable from "other system" (which is presumably "working") to this system and see if the symptoms change. This isolates issue to HBA.
                [When I bring up any sort of HBA (SCSI, FC, SAS, etc.), I always "reset to factory defaults" before getting started. Then, document the changes I make to that starting point. No guarantee that there aren't bugs or options that are unaffected by this -- but, it's a good place to start!]
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  I had a buslogic controller that did this....even after firmware updating. It ended up in the recycler box.
                  Team : 49813
                  Join in!!
                  Team Stats
                    • 31200
                    i was tempted, but i cant bring myself to scrap my 39160's
                    or maybe they are 320's - cant even remember now.
                    they have anoying mini connectors on the back plate.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I've never had a 29x or a 39x ever do anything like that. The only real wonky adaptec controllers I remember were the 2100s raid and the aaa-131u2 raid. They could be very fickle with their setup....and of course had very poor first-release firmwares...
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        Dual VHDCI. I use them to connect to my SCSI shelfs.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          I still keep modest collection of different HBA samples as there are (too!) often times when I need to build a SCSI machine for some purpose (usually related to my Sun kit). Trying to find one of a particular style/make when I need it is just a colossal waste of effort -- easier to throw them all in a box!
                          I've even got DB50 SCSI cables (along with numerous cables that morph from one connector style to another -- Centronics, DB25, DB50, HD50, HD68, VHDCI, etc.).
                          But, SCSI RAID controllers just get shit-canned.
                          • douglasfir
                            • Oct 2018
                            • 6
                            well, I've tried everything. You cannot update the firmware unless you have an eeprom programmer according to Adaptec.
                            https://ask.adaptec.com/app/answers/...are-upgrade%3F
                            All jumper settings are correct as per the drives manual, and the info in this thread. Suppose i'll have to downgrade to a 50 pin drive. that's totally ok for me. But i havent been able to find any. Thanks for helping everyone, I really appreciate it :-)
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              I assume you mean EPROM (one 'E').
                              Did you try connecting the drive to the existing controller and cable in the "other" machine? I.e., to prove to yourself that it's the drive and not the controller (or cable or settings)
                              <frown> B.C. Probably "paperwork" to ship you anything.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Back in the day, what you sold worked, there is no second chance with a firmware upgrade.
                                I don't know about SCSI as I don't recall doing this before, but definitely some PATA drives will not spin up if you connect the data cable upside down. Worth doublechecking if nothing else to check. Of course this does not apply to the D-type one way connectors, but the internal SE50s is possible...
                                I also have to mention that finding a good SCSI68 internal cable is tougher than it seems. I've a few 68-pin wide SCSI cables but they all are wonky and won't work properly except for one -- much worse than the hit rate for PATA cables which they usually just work. YMMV.
                                  • 31200
                                  maybe he has a bad active terminator.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    I've never encountered a bad internal (or external!) wide SCSI cable that was defective with a failure that wasn't obvious (e.g., bent pins in a connector). IME, machines with SCSI drives see far less "tinkering" with their internals than PATA/SATA machines. And, the folks in a position to do that tinkering tend to be "less consumer-ish" and more likely to understand what they're doing.
                                    • canadaboy25
                                      Drive SMART status not showing up through RAID controller?
                                      by canadaboy25
                                      Hey guys,
                                      I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                      Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                      I rebooted...
                                      09-24-2021, 01:56 PM
                                    • federalhouse
                                      **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                      by federalhouse
                                      I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                      **Background:**
                                      I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                      **What I've Tried So Far:**
                                      1. I accessed
                                      08-01-2024, 07:03 PM
                                    • perfm2
                                      HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
                                      by perfm2
                                      So I've worked on dozens of HP and Dell laptops and have never encountered this before.
                                      Steps taken in my usual process.
                                      Reset security settings in the BIOS
                                      Ensure existing HD comes up into the OS
                                      Shut down the laptop and disconnected the main battery
                                      Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
                                      Replace battery connector and close up the laptop
                                      Insert my USB drive with my Windows 10 image I've...
                                      03-21-2023, 08:45 PM
                                      HP ProBook 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook 600 Specification for Upgrade or Repair
                                      This specification for the HP ProBook 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                      09-06-2024, 08:50 AM
