Abit KA7 & KA7-100 recapping mods and tips [New Pics]
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Ok, there's been a flood of KA7's coming across my bench, and tons of questions filling my inbox on this board. Yes it uses those really crappy 8mm JPCON capacitors, and NO I DO NOT replace them with lousy 8mm caps! 8mm capacitors are VERY difficult to come by from a quality manufacturer, and they are VERY expensive in the event you do find some!
    I always use 10mm caps when recapping this board, with a little ingenuity and technique, they will fit and function better than the board did new!!
    The only really tricky spot on the KA7 using 10mm caps is those in front of the CPU slot. You will see from the photo's that they need to be installed at a slight angle. This prevents them from interfering with the CPU. It will also help them run a little cooler, not being in contact with the CPU cartridge. These caps get very warm when the board is powered up, even if the system is at an idle. Because of this, I recommend using 10volt caps in place of the 6.3volt caps around the CPU slot. This insures that you won't ever have this failure on your KA7 again well beyond its useful lifetime.
    I have written a detailed article outlining the recapping of the KA7/KA7-100. You can view it at: http://www.kabalsrealm.com/projects/ka7/
    Feel free to post if you have any questions!!
    Good Luck!!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • estabilito
    Tips geting oxidized when using wick
    by estabilito
    Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
    i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
    Temperature: 350-365celsius
    station: jbc cd-2bqe
    Wick: edsyn
    flux: warton hf rework jelly
    Do you have any tips?...
    04-12-2025, 11:55 AM
  • Foetuss
    Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
    by Foetuss
    Hi all
    Hope this is in the correct place.
    I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
    Could use some double checking to see if I'm not doing something stupid .
    Pictures of the boards are attached.
    What I will be replacing with what : (planned)
    Soltek Golden ::
    4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
    6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
    01-18-2025, 11:44 AM
  • Maxim Bojko
     Palit RTX 2080 Super Jetstream Mats/Mods help
    by Maxim Bojko
    I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
    After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash...
    09-18-2024, 04:18 PM
  • Shredder11
    BoardViewer Files Needed For M-Audio Ozonic Firewire Keyboard Audio Interface + Any Repair Tips
    by Shredder11
    As per title and also any tips on what to test first would be welcome on fixing this keyboard, which worked 100% and then upon the next power on, no display or response from keys, buttons, sliders, dials etc. However the Firewire audio interface section still works.
    Thanks.
    10-14-2025, 01:42 PM
  • jasonbay13
    Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
    by jasonbay13
    it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
    PU200
    pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
    pin 8 vreg3 = 0v
    pin 13 en = .2v
    pin 1,6 entrip1,2 = 0v
    b+ and b++ = 19.5v
    +5valw = 0v & 25+ohm to ground
    +3valwp = 0v & 25+ohm to ground
    i cleaned the board up just a little and can get more pics.​
    where should i be looking? thx...
    09-25-2025, 10:54 PM
