Solderless EFI Chip Card for MacBook
  • Dan20701
    • Sep 2020
    • 204
    Hello all, Can anyone tell me where I could get some blank Solderless EFI Chip circuit boards from for MacBook, So I can put on my own chip, the price of these with a chip already fitted is a joke.
    Or can I only get them if I make myself. I have searched google.
    Thanks.
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • Loki_Fido
    Requesting help identifying chip in Macbook Pro A2485
    by Loki_Fido
    Hi ya folks,
    I have this MacBook Pro A2485 (M1 Pro 2021) which came in for repair.
    It had a shorted SSD power supply chip. Therefore it was stuck at 5V.
    I replaced it and the SSD are fine. No more shorts.
    But The mac still pulls 5V and 200mA. If i leave it alone for 5 mins, the mac manages to receive 20V and 40mA. Of course, which doesnt mean the mac starts after power meter reading 20V.
    But while the mac is stuck at 5V, i checked the board with thermal and found this chip was trying to start. Chip picture is attached.
    Chip marking...
    08-07-2025, 10:17 PM
  • SSBDADC234
    MacBook Pro 14". The screen DP chip failed.
    by SSBDADC234
    When replacing the screen of this MacBook model, the DP855A chip must be moved from the existing screen for the screen to operate properly.
    However, when I removed the DP855A chip from the existing screen, I must have done something wrong and the chip broke.
    Testing the chip pins with a multimeter revealed a short circuit inside the chip.
    Is it impossible to repair this? I couldn't find a programmer for this chip, nor any eeprom programmer software.​...
    04-19-2024, 08:51 PM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
