Re: capacitor ripple vs endurance & other questions
Not ~really~ but close enough at 100kHz.
Lets run an example cap through the math so everyone finally gets it:
I chose a 1500uF 6.3v MBZ with ESR = 0.026 Ohms
[Middle of the normal range of caps on mobos and Rubycon gives actual ESR in data sheet vs Impedance.]
Z = Impedance
C = 1500 uF = 0.0015 F
ESR = .026 Ohm [squared = 0.000676 Ohm]
ƒ = 100 kHz = 100,000 Hz [Data sheet standard.]
p = PI = 3.14159
10 nH = 0.00000001 H
-- nH guessed as reasonable based on other reading. Is physical size dependent.
-- Lytics range from 4 nF for an itty bitty to 34 nF for a beer can cap.]
XC= 1 ÷ 2pƒC
2pƒC = 2 x 3.14159 x 100000Hz x 0.0015F = 942.477
XC = 1 ÷ 942.477 = 0.001061
XC = 0.001061
XL = 2pƒL
XL = 2pƒL = 2 x 3.14159 x 100000Hz x 0.00000001H = 0.006283
XL = 0.006283
(XL - XC) = 0.005222
(XL - XC)² = 0.0000273
Z² = ESR² + (XL - XC)² = 0.000676 + 0.0000273 = 0.0007033
Z² = 0.0007033
Z = 0.0265
Z is only 0.0005 different from ESR at 100kHz
That's less than 2% different.
I could never see the chalkboard in math class.Leave a comment:
Z = Impedance
p = PI = 3.14159
XC= 1 ÷ 2pƒC
XC = 0.001061
XL = 2pƒL
XL = 0.006283
Z² = 0.0007033
Z = 0.0265
.Leave a comment:
Ahh.. so impedance is ESR. I was looking for Electrostatic Resistance.Leave a comment:
The interesting thing is, if you buy in lots of 10pc or more then many times FM are less expensive than caps with less good ratings.
Only problem is sometimes FM are big for their uF and so won't fit.Leave a comment:
Calculate? There is no calculate. Just read the datasheets.
KZG is equivalent spec-wise to MBZ/WG. However, it's not recommended for recapping purposes has KZG is prone to failure.Leave a comment:
WOW!! KZE is higher ESR than FM!!!! Is KZG any better? Sorry for not looking at the spec sheets myself, I don't understand how to calculate ESR from a spec sheet.Leave a comment:
Thank you. This was very helpful. I've been struggling to understand why people recommend which series for what.Leave a comment:
One question though. When are you recommending KZE and MBZ/MCZ?
This is the way I understand it. KZE and MBZ/MCZ are Low ESR and high ripple caps. So you use them in places where low ESR is required like a motherboard's VRM. Would you put KZE let's say on a power supply?
Looking at 8x20mm
MCZ: .................... 2350 / .012
FL & FJ: ................. 1870 / .016
MBZ & WG: ........... 1870 / .019
FM: ....................... 1560 / .030
KZE, ZL, WX, HD: . 1250 / .041
KY, HE: ................. 1050 / .069
FC, PW: .................. 995 / .065
LXZ: ....................... 810 / .080
The 10x20mm follow the same pattern.
In Vcore and RAM:
KZE was the typical grade on PC133 motherboards.
By DDR RAM MBZ was more typical.
- It varies with how many cap are used because caps in parallel lowers total circuit ESR.
KZE grade is still common for the 8 & 10 mm caps used out near the add-in slots when the board has 6 or more caps out there.
Low cap-count boards will use higher grades.
.Leave a comment:
Here:
https://www.badcaps.net/forum/showpo...11&postcount=4
I did my own chart based on his info using only readily available caps from USA suppliers. No types that are N/A in US without extraordinary effort. Like Pana FJ or FL.Leave a comment:
He's only posted that info ohhhh 50 times now......
There is also a chart PC did on replacements based on application and quality/ratings. Buried in another thread and posted within past year IIRC. If I find it, I'll put the link here.Leave a comment:
This is the way I understand it. KZE and MBZ/MCZ are Low ESR and high ripple caps. So you use them in places where low ESR is required like a motherboard's VRM. Would you put KZE let's say on a power supply?Leave a comment:
The ratings to look at beyond uF and volts are ESR and Ripple.
[Remember going up in volts isn't a problem.]
ESR is isn't really Impedance (Z) - but:
At the 100kHz they use for data sheets Xc and ESL are at values such that *effectively* ESR = Impedance.
The actual equation is:
[Note: (XL - XC) must be corrected to a positive value if it isn't.]
ESR is effectively a measure of the cap's 'resistance' to AC Ripple.
Since the cap's job is to short Ripple out to ground: lower is better.
The 'Ripple' rating tells you how much Ripple current the cap can pass without overheating internally.
It is the capacitor equivalent of a watt rating on a resistor.
It tells you how 'heavy duty' the cap is and thus: more[higher] is better.
elite PF ------ 1000uf @ 16V ( 10 x 20 mm) - General Purpose cap - Ripple = 680
Rubycon PX @16v is not rated good enough.[Ripple = 640]
I would use something like LXZ, LXY, VZ, FC, PW
Capxon KF --- 1000uf @ 10V ( 10 x 16 mm) 1040 / 0.076
Panasonic FC is just good enough for this one. [KF specs are not linear, so to speak.]
Use FC or better.
capxon KF --- 470uf @ 10V ( 8 x 11.5 mm) 580 / 0.250
capxon KF --- 470uf @ 25V ( 10 x 16 mm) 1200 / 0.076
These are rated better than FC.
Chemicon KY or Nichicon HE are good enough.
Chemicon KZE and Rubycon ZL are the next better grade.
Sacon FZ ---- 330uf @ 16V ( 8 x 12 mm) - 1150 / 0.036
Pannasonic FM is not good enough. [950 / 0.056]
Use Rubycon MBZ or MCZ - Panasonic FJ or FL - Sanyo WG.
skywell SHT - 1000uf @ 6.3V ( 10 x 12 mm (not sure about height since I could'nt find data sheet for SHT) )
I would treat this the same as the FZ to be safe since I can't find a spec sheet either.
.Leave a comment:
KF I replace with UCC LXZ or LXYLeave a comment:
I see, so endurance is practically useless, thanks for clearing that up for me.
here's a list of the old capacitors that I plan to replace:
brand -------- specs
capxon KF --- 1000uf @ 10V ( 10 x 16 mm)
skywell SHT - 1000uf @ 6.3V ( 10 x 12 mm (not sure about height since I could'nt find datasheet for SHT) )
The capxon's and the elite are from lcd monitor power supplies, and the skywell & sacon caps are from video cards (AGP).Leave a comment:
I apologize, here are the values of the capacitors that I need and the sizes as well:
330 uf @ 16 V ----------- 8 x 12 mm
1000 uf @ 6.3 V ---------- 10 x 12 mm
1000 uf @ 10 V ---------- 10 x 16 mm
470 uf @ 25 V ---------- 10 x 16 mm
470 uf @ 10 V ----------- 8 x 11.5 mm
1000 uf @ 16 V ------------ 10 x 20 mm
What is the application?
.Leave a comment:
For the explanation lets say all the caps other characteristic are the same such that the useful lifetime follows the endurance lifetime.
As so:
Cap 1 - 2000hr => 6 year useful lifetime
Cap 2 - 4000hr => 12 year useful lifetime.
But because of the +/-40% accuracy...
6 years really means from 3.6 to 8.4 years and useful lifetime would be as expected.
12 years really means from 7.2 to 16.8 years and useful lifetime would be as expected.
Every single Cap 2 could fail at 7.2 years.
Every single Cap 1 could last 8.4 years.
Did the Endurance number help you? - NOPE!
.Leave a comment:
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
Channel: General Capacitor Questions & Issues
by DrewPhillipsHello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...-
by Per HanssonI have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
As I find linear high voltage regulator designs interesting I drew up the attached schematic... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... - Loading...
