Capacitor identification
  • matt701
    • Jun 2010
    Well, I don't have a picture of the capacitor at the moment but I was given a capacitor with these characteristics. I was wondering what it means.
    The capacitor is axial, made of polystyrene I believe ( it is translucent ). As well, on the capacitor, there is a value marked 33 with an F under the value and above the value. I believe this means 33 pico farads with a +/-1% tolerance? Correct me if i'm wrong. There is also a pink stripe around one end of the capacitor. What does this pink stripe mean?
    EDIT: Actually here is a link to the picture of the capacitor.
    http://www.doe.carleton.ca/moodle/fi...iki/IMG_14.JPG
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Capacitor identification
    needs a login.
    just attach it here.click on manage attachments.
    • matt701
      • Jun 2010
      Sorry. Didn't realize that. the picture was huge so i had to reduce it significantly
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        33pF with 1% tolerance sounds right to me. Only way to know for sure though would be to check with a meter.
        Since voltage is not marked in numbers on the capacitor I am guessing the Pink band is used to represent the voltage rating instead.
        -David VanHorn
