Fuhyjyyu ruined this SONY Shake X30D
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    They are still around causing headaches, this time the smaller SMPS control caps have shit their insides out and killed this PSU. Never seen any other cap to this day yet do this apart from Fuhjyyus.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Fuhyjyyu ruined this SONY Shake X30D
    Some things never change!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
      • 31213
      why is there rust stains under the transformer?
      are you sure that wasnt a victim of liquid spillage in the past?
      not trying to justify the existance of fuckyou caps, but that staining dont look related!
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        The transformer has what appears to be a "7817" date code, and that SN358P dual op-amp has what appears to be a "7247" date code. I think there may be more to that P/S's story than just F'yu caps.
        PeteS in CA
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Sorry lads I should of added. I pulled the caps and they are fully open circuit on the atlas ESR meter, the liquid appears to come from the bottom of the caps! The device it’s self has no chance of sustaining such liquid damage to just this one area as it’s sealed in a box. There would be way more evidence of this.
          Funnily enough nothing else tests faulty apart from a resistor so I’m guessing the caps failed slowly and burnt that out. If I get time I’ll make a video of it.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Need more pictures but I have to agree, this looks more like water damage, this is too much liquid for a single cap or even a few caps. None of the caps pictured could have leaked that much liquid.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Sorry guys the units been repaired today and sent, I’ve a few of the caps in the bin I’ll see if I can capture the leakage from them.
              In the end a small transistor, a 18v zener diode, 4.7k resistor and a 4amp slow blow. All fuhyjyyys swapped and it’s running.
              If it didn’t come from the caps which as I said a couple did test faulty by the area. It’s a complete mystery where this liquid damage come from. This PSU is sealed up under the mainboard, under the rest of the chassis. There would be way more signs something has dripped in there. So I don’t know
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
                Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
