[R] Capacitor brand identification
Re: [R] Capacitor brand identification
It's actually Rubycon's marking for small capacitors, according to http://capacitor.web.fc2.com. -
Great site, thank youIt's actually Rubycon's marking for small capacitors, according to http://capacitor.web.fc2.com.
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by pcconnectDead PS5 CFI-1216A, only 12v present on the board EDM-033
Blown capacitor which is located 'under' HDMI Decoder IC on the other side of the board. Does anyone know what is the value of the capacitor, please? Pics included.
Thank you... -
by jhjoveTrying to identify some SMD capacitors in a NAD audio amplifier. The markings have the value and working voltage and possibly the brand/series:
CS 22 16V
CS 10 35V
(see attached image)
The best I found for this "CS" item is YTF capacitor.
Any other thoughts? I have no experience with this YTF brand, if it is correct.
Thanks,
Joe...-
Channel: General Capacitor Questions & Issues
Hi there,
Beginner's question, sorry to waste your time...
I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... - Loading...
