Are these Samxon GT real...?
  • ethaniel
    Capacitor n00b
    • Apr 2010
    • 27
    It's an eBay Hong Kong link, shortened:
    http://******/bDRuMC
    I checked the Samxon GT datasheet and I can't see any 16v 2200uF caps with a 10 milimiter diameter there, but Big Pope have these in stock too. I'm confused here...
    AMD Phenom II X2 555 3.0Ghz @ 3.5Ghz - ECS A780GM-A v1.0 - 4 GB OCZ Gold DDR2 800 - 2 GB Kingston DDR2 800 Value - ATI Radeon HD4650 512MB - Windows 7 x64 - A bunch of hard drives
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Are these Samxon GT real...?
    cant tell from the pics they posted. would need to see the bungs to tell.
    Buy them from Joe (big pope), his are real. Caps on ebay, you have to be careful
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ethaniel
      Capacitor n00b
      • Apr 2010
      • 27
      Don't worry, I won't buy them from eBay, but it's a bit weird that Samxon is not reporting 16v x 2200uF 10mm GT caps in it's datasheet. Maybe I saw an outdated version of the PDF...? Thanks.
      • DXseekerMO
        Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
        by DXseekerMO
        Hello everyone!
        Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
        I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
        Yes
        0%
        1
        All backlight strips are the same quality
        0%
        1
        No
        0%
        0
        12-16-2021, 03:58 PM
      • myth77
        how do you resolve problems with ebay (and other shop) scammers!?
        by myth77
        When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
        So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
        First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
        09-02-2022, 04:53 AM
      • cnti
        Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
        by cnti
        Hi.
        BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
        This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
        BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
        RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
        burned, measured 10M ohm.
        QM801 [real PSU:...
        10-19-2023, 05:33 PM
      • chth96
        Can I replace KME cap with Samxon GF cap?
        by chth96
        Hello.
        I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
        Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
        I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
        04-17-2024, 07:11 AM
      • edugimeno
        Diagnose real-vintage Strong-Hammer arcade machine
        by edugimeno
        Hi there!
        My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
        I am attaching several pictures of the machine.
        It basically has 2 sides, left side has
        • 2 x 220->12+24v transformers
        • 2 relays (1 moves motor UP, other moves motor DOWN)
        • IGF and breakers for safety
        Right side is shown on pictures. It has 3 boards ( top-down)
        • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
        02-29-2024, 11:05 AM
