Exactly same capacitors from NCC and Nichicon
  • xnRS
    • Feb 2021
    • 85
    • Belarus
    I was searching some caps and found NCC KY and Nichicon UHE. I was looking for 1000uf 10v 8 x 20 mm. If you'll look into data, you'll see that impedance at 20 and 10 degress celsious is same, same applies for the ripple current. Also, I saw same thing with some other big caps(680uf 400v, or something like that, don't remember exactly) and saw same thing from NCC and Nichicon, no other manufacturer. This leads me to one idea - they are using same factory and just rebranding some caps.
    Any opinions on this one ?
  • brethin
    • Dec 2008
    • 1907
    Re: Exactly same capacitors from NCC and Nichicon
    Uh no, same specs doesn't mean same factory.
    • xnRS
      • Feb 2021
      • 85
      • Belarus
      then look into a datasheet of both caps, every cap is exactly the same
      • xnRS
        • Feb 2021
        • 85
        • Belarus
        And how they could have exactly the same specs on each cap ?
        • s675
          • Sep 2015
          • 35
          You make a good point. The specs (including lifetime) all match.
          Here are the possibilities that I have thought of:
          • One company makes the capacitors, and the other company rebrands them with their company name.
          • They are different capacitors, and one of the companies used the competitor's specs as placeholders and never changed them.
          • They both manufacture this capacitor design in their own factories. The original company agreed to share the exact formula etc under license.
          • brethin
            • Dec 2008
            • 1907
            Not the same factory even if they exactly the same specs, it's not uncommon on popular parts.
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              They’re equivalent series - same specs, but competitors, not identical factory. NCC/UCC and Nichicon are manufacturers, not rebranded.
              PeteS in CA
              • s675
                • Sep 2015
                • 35
                I'm aware that they both are manufacturers, but somebody is copying somebody else here, with or without permission. I would not think very highly of whichever one is the copycat. I'd expect actual measured spec averages if they are indeed not the same cap design.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  Nippon Chemicon and Nichicon manufacture their own parts. They do not rebrand.
                  Nippon Chemicon (NCC) and Nichicon - and others - sell similar parts that compete with each other directly. See, for example, NCC's LXZ series, Nichicon's PW series, and Panasonic's FC series, whose specs are extremely similar. This is just ordinary normal head to head competition, no permissions required.
                  PeteS in CA
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
                  • DrewPhillips
                    Capacitor Diarrhea - Nichicon PL Series
                    by DrewPhillips
                    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                    03-02-2025, 10:18 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                  • Hitto
                    Fake Nichicon capacitors with almost-perfect sleeve?
                    by Hitto
                    Fake Nichicon capacitors with an almost-perfect sleeve?
                    Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                    It truly looks like the real thing.
                    I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                    Shall we be afraid, at this point, that even the bung can be replicated?...
                    01-09-2021, 03:07 PM
                    After all of...
                    07-13-2024, 08:14 PM
