quecoo t12-952 Recap psu help needed
  • bord
    • Feb 2014
    • 19
    • South East Asia
    Got a soldering station with an internal psu (mains to 24V) which need to be recapped because the caps are all the dodgy "Yungli" brand with no series markings.
    The biggest cap at the bottom of the pic looks like a bulk cap (400V 33uF), the 2 caps at the top (35V 680uF), a small one just next to a heatsink on the left (50V 22uF), the 33uF and 680uF caps are marked with "low esr".
    Problem is that I can't get any low esr series cap in stock to replace the 400V 33uF from the local Farnell, only general purpose series available. The only option which seems to have lowish esr is the Chemicon GXF.
    My question are :-
    - does the 400V cap look like a psu bulk cap and is a low esr series cap necessary to replace it. Or can I use general purpose caps like Panasonic ED/EE/NHG, Rubycon BXC/PX/PK/TRW, Chemicon KXG/KMG/GXF etc?
    - all the caps including the bulk cap are normal polar (DC) caps right?
    • 31291
    Re: Recap psu help needed
    the 400v cap does not need to be low esr because the mains coming in is only 50/60Hz x2
    the 680uf caps sound small, if you can fit them in the case then consider 1000uf panasonic FS series.
    if this is what i think it is then do a search on this forum - the big cap is tricky because of limited case height.
      • 22182
      Whats the make/model number of this soldering station
      • bord
        • Feb 2014
        • 19
        • South East Asia
        Is that the same with newer PC psu's (which are LLC, DC-DC) as well - no need for low esr for the big bulk cap?
        There is still quite abit of space for height on the 680uf caps but not diameter. The big cap still has space for height and looks smaller compared to the silkscreen marking.
        • bord
          • Feb 2014
          • 19
          • South East Asia
          Its a quecoo t12-952, its a decent brand for this type of T12 stations.
          There was an old thread about T12 soldering stations.
          https://www.badcaps.net/forum/showthread.php?t=76911
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
            no-name Radeon 9600 XT recap and cooler
            by momaka
            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
            This one was actually suggested to me by ChaosLegionnaire....
            11-06-2020, 07:54 PM
          • DeXXter
            Replacing SOC SRK08 clean me needed?
            by DeXXter
            Hello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
            Note: After doing all...
            11-19-2025, 03:16 AM
          • mohammed mohan
            BIOS file needed HP PROBOOK 445 G6 DA0X9KMB8E0 REV E
            by mohammed mohan
            BIOS file needed
            HP PROBOOK 445 G6
            DA0X9KMB8E0 REV E
            S/N 5CD92213CN
            No backup available
            10-29-2025, 05:25 AM
          • karim011
            needed bios acer nitro N50-620
            by karim011
            Hi everyone. Plz needed bios file For Acer Nitro N50-620
            - Motherboard DIB56L 202019-1 348.0EZ07.0011
            09-20-2025, 04:03 PM
