what brand caps is this? RM
  • spiros.p
    • Dec 2020
    • 89
    • Greece
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: what brand caps is this? RM
    https://cdn11.bigcommerce.com/s-8cj0ptaaqe/images/stencil/500x659/products/185/664/$_57__20210.1535083973.jpg?c=2
      • 31209
      never heard of them.
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        i know is china crap but i wonder if someone have experience with them..
          • 21649
          RM is Sanshui Riming http://www.paullinebarger.net/DS/RM%...i%20Riming%5D/
          CD296 is a chinese standard meaning 5000h 105C SMPS caps
          https://www.eevblog.com/forum/chat/e...-does-it-mean/
          • spiros.p
            • Dec 2020
            • 89
            • Greece
            thanks for the infos guys all ready replaced that crap with nichicon SMH.
            • @udiophile99
              • Mar 2021
              • 14
              No idea my friend. However, I asked a friend to take a look at it and he told me that these are probably from China or Vietnam.
              • bestsystem
                • May 2011
                • 59
                only Samxon (Man Yue) is stable, also AiSHi does not need to be recapped often
                Avoid others at all cost, I have seen them bulged even inside a modest transistor radio.
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                  by momaka
                  03-12-2025, 03:42 PM
