Looking for a replacement cap for 820-2532-A C7252
  • rjpeek6
    • Feb 2021
    • 7
    I'm working on a 820-2532-A and have found a short across C7252 (PP5V_S3_REG, 5V out). I introduced voltage across C7252 (using an external power supply) and only the cap felt hot. When I removed C7252 the short goes way. When I measure across the cap that is removed from the board it does not measure are hard short (low resistance) but when I apply voltage only across the cap it draws alot of current from an external power supply, so I know this cap is bad. I am trying to find a replacement for this shorted cap. On the 820-2532-A schematic it list the following info about this cap:
    C7252 = 330uF, 20%, 6.3V, POLY-TANT, CASE-D3L-SM1.
    I contacted Mouser and they couldn't find a match but did reply with
    T520Y337M010ATE025 10V, 330uF, 20%, KEMET Tantaium Capacitors - Polymer
    I would like to know thoughts
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Looking for a replacement cap for 820-2532-A C7252
    That might work. You need to compare the case size on this datasheet, https://cdn.badcaps-static.com/pdfs/...7c2224d66a.pdf .
    Alternatively, check to see if Digi-Key has T520?337M006ATE0##: The "?" being whatever case code matches the size of what you are trying to replace, and "##" being the ESR (the lower the better). IOW, get the lowest ESR they have in the B, V, D, or Y case (whichever matches).
    PeteS in CA
    • rjpeek6
      • Feb 2021
      • 7
      I looked at the datasheet and it seams to be the correct size, I also showed my co-worker and he says it's a 2917. I ended up ordering 10 - 6.3V and 10 - 10V.
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
      • ezenia
        PS4 controller left stick potentiometer replacement issue
        by ezenia
        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
        09-30-2023, 02:19 PM
      • boosti45
        Macbook pro logic board replacement parts quesion
        by boosti45
        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
        08-21-2024, 05:23 AM
      • r2digital
        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
        by r2digital
        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
        04-18-2024, 03:50 PM
