Identifying a capacitor: FP10K
  • Julinoleum
    • Dec 2020
    Hello, I need help finding a replacement capacitor for an Asus Maximums VIII motherboard. It has been damaged by removing the cpu fan.
    The number says :
    FP10K
    56Lz
    561
    6.3
    I found a previous thread with someone looking for a FP10K but the subsequent numbers were different so I wonder if it needs something different?
    https://1drv.ms/u/s!AocLXoDg6GbRnb8O...gL0dw?e=Vsu1PK
  • R_J
    • Jun 2012
    • 9624
    Re: Identifying a capacitor: FP10K
    CONDUCTIVE POLYMER ALUMINUM SOLID ELECTROLYTIC CAPACITORS
    560µf 6.3v
    https://www.yoycart.com/Product/540395184609/
    • Julinoleum
      • Dec 2020
      Thanks you very much!
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Ambro
        Help identifying missing smd capacitor for HP elitebook 840 g3
        by Ambro
        In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
        I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
        I've attached a picture of where it's located on the board.
        Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
        Thank you for any help you can provide....
        09-09-2023, 06:21 PM
      • grimacelord
        Need Help Identifying Capacitor On Kar-Tech Versa Remote
        by grimacelord
        I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
        One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
        09-08-2023, 09:28 AM
      • krob80
        PS5 Edm-010 No Power - Help identifying missing capacitor
        by krob80
        Hey everyone. I recently acquired a PS5 that is not turning on (no beep/power). PSU is good and there is no shorting on the 12V rail.
        It came with a Gen3 SSD installed so I feel that things went down hill for the previous owner when it was installed. F7003 was blown but there was nothing shorting to ground. I replaced the fuse but still no power (new fuse is still good for now).
        When connecting it to a bench power supply, it only pulls 10 mA (doesn't spike when first connected).
        I noticed that there are a couple capacitors missing from the Vcore power regulator (pictures attached)....
        05-15-2025, 04:24 PM
