emerson Jacuzzi capacitor 3 pin 25UF 250v
  • Brucetafer
    • Jun 2018
    • 133
    emerson k37Gwblc-607
    Y660000 Jacuzzi Pump
    has a 25UF 250V cap with 3 pin (see picture)
    was wondering if this would be the direct replacement as the original cap was custom made and never sold.
    https://www.digikey.com/en/products/...HQA415/2231516
    other than that, I can't find anything at all.
    • Jul 2011
    • 6039
    Re: emerson Jacuzzi capacitor 3 pin 25UF 250v
    Check the two pins next to each other and see if they have a electrical connection ( 0 ohms ) if it does have one yes it should be the same
    As long as the UF value and the voltage value are the same
    • Brucetafer
      • Jun 2018
      • 133
      Yes.. I feel stupid now.. thank you so much
        • Jul 2011
        • 6039
        It is better to check for the information than to do something blindly
        • Brucetafer
          • Jun 2018
          • 133
          I need to get that tattooed on the back of my girlfriend's hand lol!!
          • djmaccllc
            • Dec 2022
            Hi
            I came across your post and I am looking for a capacitor compatible with the same Emerson Jacuzzi pump. Were you able to find one?
            Thanks in Advance
            Dan
            • redwire
              • 3907
              These are common pump, fan, motor capacitors from china. Search for "CBB61 25uF" and you need at least a 240VAC rating.
              BUT the Emerson is oddball having three spade terminals. Most common is two terminals and others have four, where the pair at each end are just connected together to simplify factory wiring. There are also flying leads versions out there. If you use a two terminal part, the two wires at the end (of the old part) need to be connected together.
              The Nichicon EEC2E256HQA415 part at Digi-Key https://www.digikey.com/en/products/...HQA415/2231516 $16 is better quality and just leave the extra terminal unconnected/unused.
              Otherwise, roll the dice and search Amazon or Aliexpress for the cheap stuff.
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • chth96
                Should I replace polymer capacitor?
                by chth96
                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                Is this ESR value of polymer capacitor correct?...
                11-18-2022, 04:22 AM
