Premium MLCC Capacitor Selection
  • The Fist
    • Oct 2020
    Hello everyone, new here!
    I am looking for some advice on capacitor section. The capacitor will be used for modern high-frequency CPU core. I am looking for a premium capacitor to drop in as a replacement for the existing MLCC's on a z390 motherboard.
    The idea is to replace the existing caps, and/or piggyback the existing caps to evaluate the effects on maximum achievable overclocking frequency.
    Project Perimeters:
    • Premium caps without going crazy on cost (Ideal <= $0.25 each @100)
    • 0805 (in)
    • 10uF - 47uF (flexible based on recommendation)
    • Working voltage will not exceed 2v
    I have a few in low ESL/ESR options in the 47uF variant picked out, but I wanted to check with you all here and see if you have any recommendations. brands/series/dialectic options...all help is welcome
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Premium MLCC Capacitor Selection
    1. Stick with the good name brands.
    2. Remember that if you use tempcos like X5U or Y5V that they can be as low as 20% of their rated value at high or low temperatures and at DC voltages close to their rating. IOW, stick to X7R or COG where you can, and if the circuit DC voltage is 2V using 25V or higher caps where you can will reduce voltage coefficient changes.
    PeteS in CA
    • bestsystem
      • May 2011
      • 59
      Are genuine COG (C0G?) capacitors available in 10 uf+?
      i have only encountered pf and nf C0Gs or NP0
      • The Fist
        • Oct 2020
        Thanks for the help
        C0G looks ideal but there is nothing even close to the size I need. I was looking at X5R or X7R, which should be the same for my use because I am not pushing high temp, in fact, it's the opposite.
        Any advice on brands? I see a lot of Taiyo Yuden, and Murata Electronics, which I am not familiar with, are they good? I also see AVX and KEMET which I know and have used in the past. I am tempted by Samsung caps, they look good and the price is very reasonable. ...any input here?
          • 31063
          Taiyo Yuden, and Murata are well established company's
          infact TY made the best cd's/dvd's on earth.
          • chj4591
            asrock h410m-hdv value of the mlcc capacitor
            by chj4591
            asrock h410m-hdv
            I wonder the resistance value of the mlcc capacitor between atx24 pin and usb3.0.
            03-08-2025, 06:47 AM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            Replaced emmc.
            Terminal log
            UART
            AC_ON
            E-B
            FDE enabled
            06-01-2025, 02:11 AM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
            HP EliteBook 830 G6 + Backpack & Premium Wireless Mouse Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 830 G6 + Backpack & Premium Wireless Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Backpack & Premium Wireless Mouse boardview and 830 G6 + Backpack & Premium Wireless Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
            09-06-2024, 03:30 PM
