Bad aluminum poly cap on Gigabyte mobo
  • DixiePenguin
    • Mar 2008
    • 77
    • Philippines
    The video quit on a GA-F2A55M-DS2, on-board and dedicated card. Power reaches the fans and lights. I checked for obvious problems and found one capacitor that felt loose, it also sat higher than the ones around it. Looking though loupe I noticed what looked like a crack. Given the location of the cap I think it may be the reason for the video problem. I have tried locating a replacement with no success, even using DigiKey chat. The first photo shows the cap markings. Second photo show how it is raised from board and the apparent crack.
    Any suggestions on a replacement for the cap?
    Thanks in advance for the help.
    Day 24 of quarantine here in Sta. Rosa, Laguna, Philippines and it beginning to get to me
    • 31288
    Re: Bad aluminum poly cap on Gigabyte mobo
    APAQ 5K series
    https://www.apaq.com.tw/en/product/C...pe/AR5K+Series
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Nichicon FP RNS series is higher quality, lower ESR, higher ripple (could not find a 100uf but 150)
      I've always disliked apaq
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Looks like it got bumped.
        I just hope those are not fake polymers, like Sacon is known for!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • DixiePenguin
          • Mar 2008
          • 77
          • Philippines
          Thanks for the help, folks. I imagine I can chase something down now and try repairs.
          • kevin!
            recapping PCB.
            • Jul 2013
            • 195
            • España
            I do not like Apaq too much, but I'm going to be honest, are not fake and they are real polymers (I have not seen any Apaq spill), and the 5K series is proving to be reliable, a friend has an Asus board with Apaq 5k and the original SSD marks almost 50,000h of use, and the computer continues to operate stable.
            And my uncle has in his office a computer with an asus motherboard with Apaq 5k and the original hard drive marks 60,000h (he never turns it off), the most curious thing is that the processor broke, but not the capacitors and it continues to work stable.
            (The broken CPU was an AMD Sempron 145, it could never be done core unlock, possibly it came from the outer side of the less pure wafer, in the end mount another Sempron 145 and the extra core could be unlocked).
            That capacitor probably suffered some accidental hit.
            Gaming pc:
            nVidia RTX 3080 TI, Corsair RM750I.
            Workshop PC:
            Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
            Server:
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5045
              • US
              yeah a decent polymer is better than good lytics.
              but apaq isn't bottom barrel for polys, but most used for cheaper equipment.
              • DixiePenguin
                • Mar 2008
                • 77
                • Philippines
                I hope this thread is not too old. Uranium-235 suggested either FP-6R3RE151M-NS or RNS0J151MDN1 as replacement for my bad APAQ 6R3AR5K101M06X5C. THe biggest difference being they are 150uf instead of 100uf. Would they be okay to use? on the Gigabyte board. Only other suggestions from component sites were $$ plus shipping $$ to Philippines.
                Thanks folks.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Yeah, the slightly higher capacitance will not be an issue at all. Generally, up to 2x capacitance will usually not cause any issues.
                  That said, before you even order the new capacitor(s), try removing the old one and measure/test it first, if you can. Otherwise replacing parts without being able to confirm if they are bad (i.e. shottgunning approach) can leave you disappointed when the issue remains unchanged with the new parts.
                  Also, worth noting is that anything AM2 and newer (AM2+/AM3, FM1, and FM2) usually has really hot-running chipsets/MCPs. It's a good idea to replace the tiny passive heatsinks on those with active (fan-cooled) heatsinks. I suspect many "defective" AMD boards died because of this.
                  My rule of thumb is, if you can't keep your finger on a component, it's running too hot and needs a fan / active cooling.
                  • DynaxSC
                    GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                    by DynaxSC
                    I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                    General test conditions:
                    - Tested with Core i5 6500 and Core I7 6700K - no difference
                    - Default BIOS settings, but tried also altering several memory setting - does not change anything
                    What is wrong:
                    With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                    When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                    03-21-2025, 06:23 PM
                    Thermal pad thickness for various laptop GPU / Graphics Cards
                    ASUS Dual RTX 2070 OC 8GB
                    ASUS ROG STRIX RTX 3080 OC
                    ASUS ROG STRIX RTX 3090
                    ASUS TUF Gaming RTX 3080 OC Edition
                    ASUS TUF GTX 1660 S-O6G GAMING
                    EVGA RTX 3060 Ti XC GAMING 8GB
                    EVGA RTX 3060 XC GAMING 12GB GDDR6
                    EVGA RTX 3080 FTW3 ULTRA GAMING
                    EVGA RTX 3080 TI FTW3 ULTRA GAMING
                    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                    Gainward RTX 2080 Phoenix GS Specs
                    Gainward RTX 3070 Phoenix 8GB
                    Gainward RTX 3080 Ti Phoenix
                    GIGABYTE AORUS RTX 3080 MASTER 10G
                    02-09-2024, 08:08 AM
                  • nikovmiroslav
                    Gigabyte A5 X1 Need Bios
                    by nikovmiroslav
                    Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                    Gigabyte A5 X1
                    From motherboard:
                    S/N: 1TNH55ER1350895
                    P/N: 6-77-NH55ERQY-D02-2CGB
                    On sticker from the back of the laptop:
                    S/N: SN21351J000657...
                    08-24-2025, 09:15 AM
                    Gigabyte G series G5 MF-5 Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
                    09-07-2024, 07:19 AM
                    Gigabyte Notebook Specification for Upgrade or Repair
                    This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
