Changing Caps?
  • ncdave
    • Oct 2003
    • 33
    Tomcat, your coils (and the replacement caps that Jackcon sent me) fixed my motherboard!! THANK YOU!!!
    -Dave
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      KILLER BEANS!! Glad I saved that old board, many times it nearly got pitched, but the pack rat that I am always told myself I'll need something off it someday...
      Glad it worked!!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ncdave
        • Oct 2003
        • 33
        Well, I was wrong. I didn't believe that the techs at Abit would replace only some of the bad caps on a motherboard. But I just (finally!) got back the RMA replacement for that BP6 that I sent 'em, and ten of its 1500uF caps are still Tayeh, the other two are Teapo. So it sure looks like they just pulled out a couple of visibly bad Tayeh caps and replaced them with Teapo caps. Sheesh!
        EC10 is just 100 uF, too.
        The 1000uF caps are all gold-writing-on-black Teapos.
        Big waste of time and shipping. I shoulda recapped it myself.
        • ncdave
          • Oct 2003
          • 33
          Well, in the interest of fairness, I should mention that the RMA replacement BP6 which Abit sent me does seem to work okay, in spite of the Tayeh caps. I still would feel a lot better if they'd replaced 'em, but (for now, anyhow) it runs fine.
          • Oxy
            • Dec 2004
            My L18 coil is dead too. Does anyone know where I could get a replacement?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Going to have to find a spare dead board and scavenge the coil from that. If you cant find one, unwind the coil, get new wire the same dimensions and length and rewind it by hand.
              Team : 49813
              Join in!!
              Team Stats
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                i think i have a good l18 on a fubared bp6
                  by momaka
                  03-12-2025, 03:42 PM
                • link626
                  TCL 43s405 power board 81-PBE045-M02 (PLE100-2A) changed out the cheap caps
                  by link626
                  changed out the cheap HEC caps on my tv power board to a mix of nichicon chemicon and panasonic caps below.
                  now there's louder buzzing noise from the yellow thing in the upper left corner. (anyone know what that yellow thing does? is that the transformer?)
                  and the screen flickers in brightness. It's a light flicker, but noticeable.
                  the buzzing ebbs and flows, like cicadas buzzing.
                  in similar fashion, the brightness flickering ebbs and flows. the flicker might stop for a minute or two.
                  these are all low esr caps, and I'm wondering if that might...
                  08-08-2021, 11:11 AM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
