Improving CRT geometry by upgrading capacitors
  • Hitto
    replied
    Re: Improving CRT geometry by upgrading capacitors
    Other informations found while searching that I wanted to share.
    In case you want an exact-fit replacement the electrolytic capacitor is the Nichicon UHA1H3R3KHD (3,3uF 50VDC rated at 6A).
    The most capable component in this path, if we do not want to use a film capacitor, seems to be the UHA1H4R7KHD (10uF 50VDC rated at 10A).
    I am going to test, in the following order:
    6,8uF 630V (MKP)
    10uF 50V (Electrolytic)
    3,3uF 50V (Electrolytic)
    Other stuff:
    https://cdn.badcaps-static.com/pdfs/...96564c4d75.pdf
  • Hitto
    replied
    Thank you.
    Found some capacitors which should be able to sustain the required current, which will be not less than 8A. They are the B32774P TDK film capacitors.
    In case anyone will find it useful, these are the full specifications:
    https://cdn.badcaps-static.com/pdfs/...61730aa80a.pdf
    The 6,8uF 630V capacitor is able to sustain 10.4A of current while the the 3,0uF 630V capacitor is able to sustain 6.0A. I'm going to try the 6,8uF 630V and see if this difference (3,3uF>6,8uF) is going to alter the geometry or not (I guess yes, but the 3,0uF 630V may be not enough to carry the required current and, if I'm not mistaken, that scan capacitor is a critic component that cannot fail for the sake of nearby components).
    Another serie with high ripple capability is the MKP1848H manufactured by Vishay.
    replied
    pulse current.
    some polyesters and polypropylene caps wont be happy so read the datasheets.
  • Hitto
    replied
    I meant the scan capacitor, which will have to sustain 8-10A of current. Is a standard MKP capacitor able to sustain that much current or do you think that a parallel (2.2+1uF or 2.2uF+2.2uF) will be necessary?
    replied
    if B+ is 160v which sounds high, you can use a 100v polyester - a 250v would be o.k.
  • Hitto
    replied
    Thank you all.
    Do you think a polyester capacitor, let's say a 3.3uF 100V one, is alone able to withstand 8-9A of current?
    a full white screen can sometimes shrink the image because it draws more current
    That is true. It also caused whining on that CRT. Would this effect be toned down by upgrading of capacitor filters on 160V line? The board has by default design 22, 33 and 10uF of decoupling near the pins of the trafo.
    I assume that the 160V line is quite crude in terms of ripple.
  • R_J
    replied
    Originally posted by Hitto
    I'm trying to improve the geometry of a CRT monitor by upgrading capacitors.
    This CRT has a 3.3uF capacitor and I'm currently thinking of using a 6.8uF capacitor.
    If you change this capacitor value the horizontal linearity will be effected and the geometry will look like shit. Like it was stated, the values are picked for a reason.
  • eccerr0r
    replied
    This web page is pretty much a full white screen?
    replied
    that cap is selected for a reason,
    the only caps worth upgrading are the smoothing caps on the outputs of the transformer.
    even then, most people wont need it - a full white screen can sometimes shrink the image because it draws more current - but a white field is unusual except in some games.
  • Hitto
    started a topic Improving CRT geometry by upgrading capacitors
    Compared to the original ones, I've upgraded by 15-20% the capacitance of each capacitor around the flyback trafo and used components with higher current capabilities.
    Howewer, the scan capacitor (the big 3.3uF bipolar capacitor in the horizontal section) is what is giving me trouble.
    Do you guys know if going higher with the capacitance will make possible to obtain a better geometry or will it only affect the horizontal width of the picture?
    Is a polyester capacitor limited in current capabilities, giving that this capacitor will have to handle more than 8A of current? A parallel will be very hard to perform since the space is restricted by nearby components and polyester capacitors already have quite large lead spacing.
    I've seen CRTs using 3.3uF, 4.7uF and even 10uF. This CRT has a 3.3uF capacitor and I'm currently thinking of using a 6.8uF capacitor.
    Once the board will be assembled it will be quite troublesome to resolder a new one due to lack of space, so I would like to know more informations about the choice of this (critical) component.
  • chth96
    If I replace with inferior capacitor, Is it No harm to other IC components at all?
    by chth96
    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
    I know that these capacitor will not last as long as nichicon capacitor...
    12-22-2023, 04:34 AM
  • chth96
    How can I test non-polarized capacitor?
    by chth96
    I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
    I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
    And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
    I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
    06-02-2024, 07:31 PM
  • dragon3x
    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
    by dragon3x
    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
    power on.
    Here are some examples :
    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
    switching supply area).
    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
    than 6.3 V.)
    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
    I replaced capacitors with aluminum-polymer.
    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
    03-21-2025, 02:46 PM
  • chth96
    Is it no harm to replace with capacitor without ripple current rating?
    by chth96
    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
    Rubycon YK DataSheet (b...
    04-19-2024, 05:19 AM
  • chth96
    Should I replace polymer capacitor?
    by chth96
    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
    Is this ESR value of polymer capacitor correct?...
    11-18-2022, 04:22 AM
