Please Help!!! Evercon E69F
  • wfkwong
    • Sep 2009
    Do anyone know the value of E69F? Voltage and Capicator volume.
    Thanks all.
  • linuxguru
    • Apr 2005
    • 1564
    Re: Please Help!!! Evercon E69F
    Evercon E69F is a capacitor series (i.e. a type of capacitor). It will be available in a wide variety of voltages and values. BTW, Evercon is a well known crap cap, made by GSC.
    • wfkwong
      • Sep 2009
      thanks. I found that my motherboard have a cap named E69F and it may be corrupted. I want to replace it but don't know the capactiance and voltage. As you said, I think I need to guess all about this information.
      • karthur
        Vizio D65x-G4 Volume changes on its own
        by karthur
        On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
        It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
        06-05-2025, 08:13 AM
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • BigOof
        Marantz SR5007 popping on volume change and mute in Direct Mode
        by BigOof
        I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
        12-12-2024, 06:15 AM
      • Storyteller12
        Samsung Soundbar Q900T Cuts Off if Volume above 30
        by Storyteller12
        I have this soundbar and when I turn it on it works until I turn the volume above 30.
        Then the display show “PROT” protection and shuts off.
        I can turn it right back on and it works until volume hits 30 again.
        There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
        I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
        It will play fine for hours with volume...
        03-21-2023, 12:31 PM
      • Coert van Dorsten
        Sansui Integrated Amplifier replacement volume control troubles
        by Coert van Dorsten
        Hi all you clever electronmic gooroos!
        I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
        10-15-2025, 02:54 PM
