CHEMI-CON 4700uF AH Alternatives ?
  • ketone
    • Apr 2017
    • 21
    Hello Forum
    Looking for advice ... need to find an alternate Capacitor so I can replace four:
    Bulging Chemi-Con 4700uF, AH Series, 50V DC, 85c, 28mm x 45mm Radial Electrolytic Capacitors installed in a decent Audio Amplifier Power Supply.
    I have searched for anything more about the 'AH' Series ..but found nothing...they must be a special for the Amplifier Im thinking.
    What is the best Capacitor that I could replace these with ?
    Thanks in advance.
    • 31015
    Re: CHEMI-CON 4700uF AH Alternatives ?
    you dont really need to search "AH", the fact that they are rated at 85' means they are just general purpose crap.
    all decent caps are rated for 105'
    • mariushm
      • May 2011
      • 3799
      More modern series of capacitors will be often smaller for the same capacity and voltage rating, so you can also choose to go with 63v rated capacitors (next voltage rating above 50v)
      Since it's a 85c capacitor, it's just a general purpose capacitor, nothing special about it.
      No need to go with ultra low esr series of capacitors, just go with something more common.
      Some suggestions... : https://www.digikey.com/short/ph1qv5
      Majority of those there will do.. I've filtered to show only 105c rated capacitors, with 50v or 63v rated voltage, 4700uF in capacitance. Some are "snap in" capacitors, not leaded..so if you decide to go with snap in make sure the holes are in the correct spacing and all that.
      Also considering it's for an audio amplifier, you will probably be just fine with the next standard value up in capacitance, 5600uF... here's some that would work : https://www.digikey.com/short/ph18t5
      • ketone
        • Apr 2017
        • 21
        Ty Mariushm very helpful!... I will have to check to see if a Snap-in will fit...will remove an existing Cap and have a look. Cheers
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          With Chemi-Con, 85C "general purpose crap" is high grade "crap". And the 50V rating is an indicator that it was in something several decades old. All in all, you likely will be able to find a suitable general purpose 105C, 63V part. Do stick with a good brand like Chemi-Con, Nichicon, Panasonic, or Rubycon.
          PeteS in CA
          • ketone
            • Apr 2017
            • 21
            Thanks Pete
            The unit is 2003 so you are spot on.
            What decade/years did Snap In capacitors start being used? do you know... curious and thinking as the unit is so old they might be Radial Through Hole Caps.!?
              • 31015
              snap-in's have always been arround, they are just a type.
              you have wire ended, then snap-in and then the big cans with tags/bolts.
              a way to spot the difference, snap-in's have 10mm spacing between the pegs abd they are not straight wires.
              • ketone
                • Apr 2017
                • 21
                Thankyou
                Found Spacing is 10mm so snap in should fit.
                  • 31015
                  remove the old one to check - snap-in have large holes for the snap-in clips.
                  • ketone
                    • Apr 2017
                    • 21
                    ...removed and yep its a Snap-in ! ..will order Snap-in Caps now with confidence,.
                    • MrCommunistGen
                      Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                      by MrCommunistGen
                      My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                      I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                      07-12-2021, 05:11 PM
                    • UserXP
                      Mackie CR4 amplifier no sound
                      by UserXP
                      Hi, people.
                      I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                      Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                      10-17-2020, 05:06 PM
                    • Perry Babin
                      Operating caps well below rated voltage
                      by Perry Babin
                      I think this has been answered but I couldn't find the thread.
                      Someone asked me if it would harm a capacitor (10F [not a typo], 24v) if it was operated on nothing more than 12v.
                      So, I ask... Does it change any of the capacitor's characteristics/parameters/? in any way if it is never operated near rated voltage?
                      If operated for years at 1/2 rated voltage, does it accept full rated voltage like it would if it had always been operated at the higher voltage?
                      Or would it require reforming?
                      05-23-2024, 05:43 PM
                    • Francesc V.
                      Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                      by Francesc V.
                      Hi:
                      I've realized that one of the channels of this amplifier has no proper sound.
                      This is the signal at the speakers output.
                      As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                      Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                      07-15-2025, 01:33 AM
                    • waspie
                      Aiwa GX-770 Amplifier Protection Circuit
                      by waspie
                      I am by no means an expert on this type of troubleshooting but I can follow direction real well.
                      I'm no stranger to using a meter and soldering iron so I'm looking for some help in fixing an old amplifier/system I got. This is part of a system "V-1200" by Aiwa where there are several components. My first problem seems to be the amplifier.
                      It seems to be in protection. When first turned on I hear the inital relay coming on but never the second relay which is connected to the protection IC. I don't see any obvious bad components on the board. If I ground the...
                      11-29-2022, 09:58 AM
