help with 3.3 v chip
  • karwan212
    • Jun 2019
    • American Samoa
    hey guy's im kinda new here
    i have a hp omen laptop yesterday it suddenly turned off
    and didn't turn on again no led no charging led nothing
    so after opening it turns out to be what i thing its a 3.3 voltage regulator ( MS6IR ) not sure if its correct
    that getting really hot when power plug in
    so i searched online for the chip to order one but i couldn't find it
    so it would be really great if one of you know whats the real name of it
    heres a photo of it
    https://photos.app.goo.gl/cGQNke31bpctGwYb8
    • 30917
    Re: help with 3.3 v chip
    give the exact make & model etc of the laptop and any name / ID on the circuit board.
    a schematic may be needed.
    it could be a bad chip, but it could also just be getting hot because something downstream is shorted.
    (like a ceramic capacitor)
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • BMCappelletti
      Asus Chromebox CN62 - wrong chip put on BIOS reader
      by BMCappelletti
      Long story short:
      - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
      - gave the computer to his son a couple years later
      - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
      - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
      (seems like the story was not that short)
      He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
      01-08-2025, 07:27 PM
    • Troystain
      Help EZP2023+ updated chip database for w25q256jveq?
      by Troystain
      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
      I need to add w25q256jveq chip but I do not know what data should I type.
      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
      11-25-2024, 12:53 AM
    • inck243
      Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
      by inck243
      Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
      The BIOS...
      07-25-2024, 09:17 AM
