Unidentified Capacitor
  • dennis_elx33
    • May 2019
    • 32
    • Malaysia
    Hi Guys,
    I am an electronics tech repairing power supply and other elex devices. It happened that I repaired 1 lambda power supply and found 1 capacitor burnt. I compared it with 1 good unit and was able to get the top marking of it. But the problem is, I cannot find any information/datasheet of the said capacitor online. I tried to source and ask electronic store online like digikey but all got negative response as they cannot find any info about it also. I tried to measure the good cap from other unit and it measures 220nF on board. The top marking is AVX CDM-22-0169744A. I hope you guys can give any info/suggestions on what capacitor should I use to replace this. Thank you in advance!
    • 31139
    Re: Unidentified Capacitor
    most likely CDM-22-016 is the part number and the last line is the date it was made.
    given your checking of the other one, it may even be:
    CDM = range
    .22 = capacitance
    .016 = voltage (160v??)
    • dennis_elx33
      • May 2019
      • 32
      • Malaysia
      Hi Stj! Thank you very much for the idea. Having said that, do you think i can use any ordinary ceramic capacitor to replace this one? It seems that this cap got special characteristic because the packaging type (8-pin DIP package) is not same with any ordinary caps. Though i don't have any datasheet to confirm. Hope to hear from you again. Thanks in advance!
        • 31139
        ordinary?
        this is just big.
        • R_J
          • Jun 2012
          • 9579
          What part of the circuit is it located?
          That might be either an old number or custom part number.
          You say the value you measured is .220 µf correct?
          If you can't find a replacement, try contacting AVX, they likely have a direct replacement
          • R_J
            • Jun 2012
            • 9579
            It could just be a very low esr capacitor that is used in the output of the power supply, I see they will use these stacked mlcc types in place of large electrolytics
            • dennis_elx33
              • May 2019
              • 32
              • Malaysia
              Hi Stg, thanks for the reply..i will just try to find other options.
              • dennis_elx33
                • May 2019
                • 32
                • Malaysia
                Hi RJ,
                Kindly see the actual photo of the pcb circuit. Yes, I will try to contact AVX about this. Its 220nF so by conversion its 0.22uF. Thank you very much for the suggestions.
                • R_J
                  • Jun 2012
                  • 9579
                  I suspect it is the high voltage type.
                  • dennis_elx33
                    • May 2019
                    • 32
                    • Malaysia
                    Hi RJ, Thank you very much for your idea and for this datasheet. Anyway, I already sent email to AVX and still waiting for their reply. I will update you the result later. Thanks again!
                      • 31139
                      Lambda??
                      what is this? maybe we can find a schematic.
                      • dennis_elx33
                        • May 2019
                        • 32
                        • Malaysia
                        Hello stj! Yes, this is lambda power supply. Thanks in advance.
                          • 31139
                          model?
                          • R_J
                            • Jun 2012
                            • 9579
                            Someone was looking for the same part but a different power supply a few years ago (HAL-02-655), I suspect the number is lambda's own number on that part.
                            • dennis_elx33
                              • May 2019
                              • 32
                              • Malaysia
                              Hi Stj, the model is pfhc-2600..thanks
                              • dennis_elx33
                                • May 2019
                                • 32
                                • Malaysia
                                Hi RJ, I guess so..I'm still waiting for AVX's reply on my inquiry email. Still hoping they will reply by this week.
                                • R_J
                                  • Jun 2012
                                  • 9579
                                  If you don't here from AVX, try TDK-Lambda, they might be able to supply the part.
                                  Here is the other picture I found, same numbers except the last which I suspect is the date/mfg. code.
                                  • dennis_elx33
                                    • May 2019
                                    • 32
                                    • Malaysia
                                    Hi RJ, ok I will try your suggestion. Thanks a lot!
                                      • 31139
                                      yes, good photo.
                                      last line on the cap: 9726A < 26th week of 1997??
                                      printed on the pcb: 3197 < 31st week of 1997??
                                      dennis cap is 9744A and the pcb is 9825.
                                      i am now 100% sure i was right.
                                      the capacitance, possibly the voltage, then the mfr date.
                                      • dennis_elx33
                                        • May 2019
                                        • 32
                                        • Malaysia
                                        hi stj, thanks for your idea..anyway I tried to buy the mlcc cap with 220nF/630V rating because I cannot find the exact part online.. I will inform u guys later whether pass or fail after I install the part and do the testing.
                                        • Prolog
                                          by Prolog
                                          12-01-2024, 08:27 PM
                                        • chth96
                                          by chth96
                                          12-22-2023, 04:34 AM
                                        • chth96
                                          by chth96
                                          06-02-2024, 07:31 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • chth96
                                          Should I replace polymer capacitor?
                                          by chth96
                                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                          Is this ESR value of polymer capacitor correct?...
                                          11-18-2022, 04:22 AM
