Replacing capacitors on Gainward GTX Titan, which ones to choose?
  • Jake77
    • Mar 2019
    • 6
    • Finland
    I should be replacing capacitors on my graphics card. The current ones are:
    A3
    OCRZ
    270
    16V
    Height and diameter are both 8mm. Which capacitors should I buy to replace them?
    From Nichicon I found these, would they do?
    RL81C271MDN1PX
    At least size would be the same..
    • 30937
    Re: Replacing capacitors on Gainward GTX Titan, which ones to choose?
    what's wrong with the old ones?
    • Jake77
      • Mar 2019
      • 6
      • Finland
      Well, the card does not work in games any more. It's ok to boot to windows and desktop use, but when starting any game with 3d graphics, the computer freezes with gray screen. Then need to power off the pc and restart it to get it up and running again. I was just thinking that when 3d graphics starts, then the card starts pulling much more watts than in desktop use, and capacitors are needed to supply it. So that lead me to suspect that there might be issues with capacitors.
        • 30937
        got any pictures?
        i'm sure the original caps will be polymer, i'd be looking in your psu first!!!
        • Jake77
          • Mar 2019
          • 6
          • Finland
          Here's a pic of the capacitors.
          Regardng the PSU of the computer, I have tested the PC using GTX 460 card, and everything was working fine with that card. Also the height of the capacitor is important as there is a heatsink which does not allow for any taller capacitors
            • 30937
            Lelon OC-CON polymer caps,
            they shouldnt degrade.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              u can try recapping if u want but dont expect it to work. the issue u are getting is more of a failing gpu chip rather than bad caps. i had a couple of failing gpus before that work fine in 2d but if u run anything 3d, it either freezes or crashes instantly.
              • Jake77
                • Mar 2019
                • 6
                • Finland
                Thanks for the replies.
                This is kind of hobby project, as I already have a new graphics card on my pc. In case I wanted to practice and try to change the capacitors still, just for fun, so which capacitors are ok? Would the nichicon RL81C271MDN1KX be ok?
                How is the quality of Lelon nowadays, are they ok?
                I read from the forum that at least previously Lelon made some bad quality caps?
                  • 30937
                  i have never seen bad lelon's
                  but we are talking polymers here anyway - references to bad caps are about liquid-filled electrolytics.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    could be another bad component dropping voltage when the GPU starts to pull a certain amount of amperage. but diagnostic for that kind of thing would be very difficult
                      • 30937
                      not really, if the card is using just external power cables and not drawing via the pci-e slot then a dc clampmeter could see the level.
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        I mean to find the specific fet that's doing it
                          • 30937
                          stick your finger or a thermocouple on them - a bad one will get hotter
                            master hoarder
                            • May 2008
                            • 12164
                            This. ^
                            You likely have a failing video card, and there's not much you can do about it. You can try to reflow it, but it may or may not fix the issue (and the fix may not last long.)
                            If you want to practice recapping, don't waste your time and caps on this card - it's hard to learn on them if you never done it before, because they have very thick copper traces and will sink heat away from your iron very quickly. So unless you really have a good iron, chances are you will struggle. Thus, if you want to practice recapping, grab an older motherboard or a PSU known for bad caps, and recap that instead. PSUs are probably the easiest to work on, so I recommend starting with that. You will also end up with a reliable test PSU afterwards (that is, if it's a known good brand PSU, of course.)
                            • Jake77
                              • Mar 2019
                              • 6
                              • Finland
                              Thanks for all your replies and comments.
                              Ok, sounds like just better let this card go and move on
                              And practise with PSU first, if want to have some soldering experience.
                                master hoarder
                                • May 2008
                                • 12164
                                Well, if you are thinking of throwing it away, consider listing it on eBay or your local classifieds/auction sites for cheap. Some people do buy them for their heatsinks or even to attempt to reflow them (which sometimes can fix the card back, though the fix is usually temporary.) Or are you going to keep it as a decor ornament? I know I have a few cards like that.
                                • Stefan Payne
                                  • 1267
                                  Originally posted by Jake77
                                  Well, the card does not work in games any more. (...) but when starting any game with 3d graphics, the computer freezes with gray screen. Then need to power off the pc and restart it to get it up and running again. I was just thinking that when 3d graphics starts, then the card starts pulling much more watts than in desktop use, and capacitors are needed to supply it. So that lead me to suspect that there might be issues with capacitors.
                                  No, there is more to it.
                                  I have a similar card but didn't bother with it.
                                  The Problem you have right now is that you do not know if the Chips degraded or the Powersupply for the Chip.
                                  And for that you might need a scope and know how to use it on a GPU...
                                    master hoarder
                                    • May 2008
                                    • 12164
                                    Whaaaaaat??!
                                    The GPU "VRMs" either supply power properly or they don't at all. There is no such thing as "degraded [VRM] chips". GPU is just dead/dying (mechanical solder failure between core and substrate). Make no more or less out of it. In rare cases, you may have tin whisker growth between traces on the PCB or the GPU BGA, or some via failing... but again, that is rare.
                                    • Tyran
                                      Replacing capacitors on a 12v 5000w Pure Sine Inverter .
                                      by Tyran
                                      Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
                                      04-22-2022, 08:26 AM
                                      MSI Gaming TITAN GT77HX 13VI-044 Notebook GT Specification for Upgrade or Repair
                                      This specification for the MSI Gaming TITAN GT77HX 13VI-044 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TITAN GT77HX 13VI-044 boardview and TITAN GT77HX 13VI-044 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      09-07-2024, 06:31 AM
                                      MSI Gaming GT77HX 13VI-009NL Titan Notebook GT Specification for Upgrade or Repair
                                      This specification for the MSI Gaming GT77HX 13VI-009NL Titan Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT77HX 13VI-009NL Titan boardview and GT77HX 13VI-009NL Titan schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      MSI Gaming Titan GT77HX 13VH-033 Notebook GT Specification for Upgrade or Repair
                                      This specification for the MSI Gaming Titan GT77HX 13VH-033 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Titan GT77HX 13VH-033 boardview and Titan GT77HX 13VH-033 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                      MSI Gaming TITAN GT77HX 13V1-044 Notebook GT Specification for Upgrade or Repair
                                      This specification for the MSI Gaming TITAN GT77HX 13V1-044 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TITAN GT77HX 13V1-044 boardview and TITAN GT77HX 13V1-044 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
