PCB pads problem?
  • BigAlNZ
    • Mar 2008
    • 65
    PCB pads problem?
    Hi Guys,
    When I recap, until I get my desolder gun, I just use wick, iron and a big safety pin for clean out the holes in the PCB.
    Now occasionally I think I am destroying the small pads on the bottom of the PCB, this combined with perhaps not quite the right cleaning technique means that when trying to solder the new caps in the solder doesnt flow.
    I have got flux clean and ISO alcohol. So after removing all the old solder, is that when I use the flux clean, or alcohol or both? Or is the flux clean only for when you have put the new caps in and are cleaning up?
    I need to get a bit better at this.....
    When the holes are clean, and the pads are there the solder flows really nicely.
    -Al
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • dbuergi
    Restore solder pads for SMC on MacBook A1466
    by dbuergi
    i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
    Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
    As written i want to improve skills so it doesnt matter if it takes longer.
    12-29-2024, 10:24 AM
  • langbaobao
    DIY 3D-Printer WSON8 Pogo Pin Adapter
    by langbaobao
    Hi.
    I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
    I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
    01-08-2024, 05:58 PM
  • chth96
    Is it good to use chemistronic flux off es835b for flux remover?
    by chth96
    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
    11-17-2023, 07:25 AM
  • abajor
    A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
    by abajor
    Like title says A2141 came in with Water Damage, customer desperately wants the data.
    The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
    I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
    That said after cleaning up the...
    12-21-2024, 07:16 PM
