Nichicon radials without the X vent?
  • nmantas
    • Feb 2019
    • 4
    I recently bought some Nichicon caps on eBay (yeah, I know). These are small 4x7 radial 16V 10uF caps. I feel they are fakes because the plastic pattern on the bottom and they don't have the X-vent stamped in the aluminum end and all the datasheets I have read indicate there is a vent(not exactly sure what series they are....or are supposed to be). I don't really care about the couple dollars wasted but when I let the seller know he thought they were real and he doesn't want to sell fakes. I thought I would do a little research and let him know. Is the lack of the characteristic X enough to prove they are fake or does Nichicon sometimes not stamp the very small radials such as these?
  • lti
    • May 2011
    • 2557
    Re: Nichicon radials without the X vent?
    Caps that small won't have vents.
    Those look like either USV (25V) or USF (16V) series.
    • nmantas
      • Feb 2019
      • 4
      They are 25V and not 16V like I originally said. The USF datasheet even gives the footprint of the plastic on the bottom and it seems like a match and not the typical footprint of Nichicon caps. Perhaps they are legit after all (I don't know if it is worth bootlegging these little guys)?
      • redwire
        • 3912
        I have some UPW1E100MDD6 from Digikey. No X vent, and no flat bung, and N621 text as well. The white printing is strong, not washed out like the fakes.
        • nmantas
          • Feb 2019
          • 4
          Mine have N823 on them.
          My text isn't that bad but does look a little pixelated on the edges. Besides that, all other indicators now seem to point to real and there probably isn't enough of a profit margin to bootleg these little guys and make any money at it.
          • DrewPhillips
            Capacitor Diarrhea - Nichicon PL Series
            by DrewPhillips
            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
            03-02-2025, 10:18 PM
          • nick3092
            Mid/late 80's Nichicon Yellow Caps
            by nick3092
            I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
            08-28-2022, 03:56 PM
          • chth96
            Is there datasheet for nichicon LXJ series?
            by chth96
            I want to calculate capacitor ESR referring to below guide.
            https://forum.digikey.com/t/calculat...-from-tan/2633
            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
            11-20-2022, 08:11 AM
          • chth96
            Is there any datasheet for nichicon RT(M) series?
            by chth96
            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
            https://www.badcaps.net/forum/troubl...e-been-blew-up
            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
            I have spare console...
            11-28-2023, 03:36 AM
          • Jim P
            Nichicon VX replacement
            by Jim P
            Current project is almost all Nichicon VX capacitors (20%) which appear to be discontinued. Any recommendations for a high quality replacement? Thanks
            10-27-2025, 08:29 PM
