bad panny fj. low capacitance, high vloss. what happened?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    recently, i tested some panny fj caps that i pulled from an asus a8v board some years back. these caps are 820 µf 6.3v rated and they all tested low capacitance with a reading of around 550 µf with a vloss of 5%. the esr tested normal tho.
    these caps were used as general filter caps around the board for the minor rails. none of the caps show any signs of bulging. it should be noted the board was used with a capxon psu which seems to output a ton of ripple making the board unstable and failing to boot after a year of use.
    so my question is what happened internally to the panny fj caps to make them low capacitance and high vloss? my assertion is that the excessively high ripple would make the electrolyte evaporate due to internal heating from what i know but none of the caps show any signs of bulging (there are over 20 of them!) so im not sure if my hypothesis is correct. so i guess these fj caps are drying out internally if they exhibit low capacitance and high vloss due to loss of electrolyte? it seems like caps only bulge if heat abused but not if electrically abused. need to know if my understanding of all of the above is correct so i can avoid this type of failure in future and not use junk failing psus and killing my mobos. thanks.
    • 31050
    Re: bad panny fj. low capacitance, high vloss. what happened?
    nothing lasts forever,
    i have seen pany FC leak at the leads multiple times,
    and had a ruby MBZ explode because the board had not been powered for several years.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I've pulled lots of bad pannies out of Dell systems. They aren't indestructible.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        Here are three posts documenting silent FJ failures:
        https://www.badcaps.net/forum/showpo...77&postcount=1
        https://www.badcaps.net/forum/showpo...&postcount=241
        https://www.badcaps.net/forum/showpo...90&postcount=2
        Low capacitance and in-spec ESR / high leakage current could denote that the anode foil has degraded. Capacitance depends upon the thickness of the anodic oxide film and how well the anode foil is formed and etched (some electrolyte is also necessary). Liquid electrolytics don’t need to experience thermal duress to bulge - overvolt one, reverse polarize one, manufacture one with an unstable electrolytic formula (KZG and KZJ) or shoddy raw materials (many a bad brand), and hydrogen gas will form (and a hiss or a bang will likely precede that proviso if it happens quickly enough).
        My understanding is that the Dell systems of old, whether they are USFF, SFF, slim desktops, or even mid towers, tend to run on the hot side by default, so I’m not surprised that even Panasonics would eventually fail there. I’ve also kept wary of Panasonic FC leaking from the bung - I don’t know if it’s because their bungs are just softer and don’t take well to heat or if they’re simply decomposing over time. I consider Rubycon MBZ exploding after years of storage to be a tad more concerning. I’ve seen that happen lots with Nichicon HMs made before the second quarter of 2005 (as well as various crap brands), but not with MBZ. I would be curious to know what output that MBZ was filtering, the PSU feeding it, its capacitance and voltage rating, date code, etc, if such details were committed to memory. I realize capacitors aren’t meant to sit on the shelf forever and that the oxide layer needs to be reformed after years of disuse, so it may have been a factor.
          • 31050
          the MBZ was on the5v rail and 10v rated,
          i suspect it simply needed re-forming because it had sat with a load across the terminals for several years.
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3264
            • Singapore
            ah well... i guess that means i just have to take very good care of and be very nice with my ultra-low esr lytic caps. keep them actively cooled with a fan near them and no junk cap psus. only ultra-low ripple jap cap psus. also have to take them out of storage every year or so to reform them so that they dont pop.
            with all this "fragile glass construction" of ultra-low esr lytics, its no wonder they got deprecated in favor of polymers. maybe i should start polymodding some stuff i dont use often.
            • Green Probe
              Recapping a Denon AVR X6400h SMPS
              by Green Probe
              (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
              Disclaimer: I'm an amateur hobbyist and will get things wrong.
              Always use caution when working around mains power and high voltage capacitors!
              Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
              SYMPTOMS:
              -No display...
              07-18-2025, 03:36 PM
              Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
              I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
              I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
              I tested the battery cells there are installed right now and they are testing good with no issues that I...
              02-04-2025, 08:08 PM
            • harp
              high voltage high resistance marking resistor
              by harp
              Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
              08-26-2024, 01:42 PM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • SwedishDiesel
              Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
              by SwedishDiesel
              Howdy folks,
              I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
              10-30-2021, 12:47 AM
