Is this PSU capacitor bad?
  • Tom41
    • Oct 2005
    • 336
    • England
    My PC was failing to stay powered on and seemed to have to 'warm up' before it could be adequately used. Frequently it would just power itself off again mid-way through the POST.
    Opened up the computer, nothing obviously wrong with the motherboard or connections. Then I popped the lid on the PSU and saw... THIS.
    My question is, is this capacitor leaking gunk, or is it just something they put on in the factory to minimise vibrations (as I've seen on other PSUs)? You'd think that if it was the latter, there would be similar stuff on the other input capacitor...
    Certainly no signs of bulging on either of them!
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Is this PSU capacitor bad?
    i'm pretty sure the cap is busted and leaking. and its a junk fhy cap to boot. time to bust out the soldering iron.
      • 31214
      that's 100% guilty.
      but because of how they work, replace them as a matching pair.
      dont just replace 1.
      • dmill89
        • Dec 2011
        • 2534
        Originally posted by stj
        that's 100% guilty.
        ^This
        The 4-diodes in place of bridge rectifier and thin heat sinks don't exactly give me much confidence in general. Since bulk caps (at least good ones) generally aren't cheap (and if those failed I wouldn't expect the ones on the secondary side to be much better), depending on the quality of the PSU (can only see so much from that one pic, but what I see isn't good) you may be better off just replacing the whole PSU with a better unit.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Originally posted by dmill89
          ^This
          +1
          Don't bother repairing it. You can get yourself a nice budget EVGA unit for $40 or so.
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • chth96
            If I replace with inferior capacitor, Is it No harm to other IC components at all?
            by chth96
            I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
            Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
            It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
            So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
            I know that these capacitor will not last as long as nichicon capacitor...
            12-22-2023, 04:34 AM
          • chth96
            How can I test non-polarized capacitor?
            by chth96
            I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
            I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
            And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
            I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
