Bad caps in two digital photoframes
  • kpark
    • Jul 2018
    • 3
    I have gone round and round with two companies trying to get parts for two digital photoframes with bad caps. It appears both units have the same caps, yet since they oozed out, I can't find any identification on them. I have uploaded a pic in hopes someone may be able to tell me what they are.
    Cheers and thanks,
    Kim
    • 31288
    Re: Bad caps in two digital photoframes
    those are crystals, the brown shit is glue!
    • kpark
      • Jul 2018
      • 3
      stj,
      Pretty quick response, thanks. Any idea why these are in a photoframe? I can't find a schematic and they both will not power on, with solid power supplies. If that is glue, then it oozed out all over the placed in the other unit.
      • R_J
        • 9624
        Those are crystals thatare required by the microprocessor ic, they are glued in place so when people drop and bang the frame around the crystals that have fine wire leads don't break off the board.
        Whats the model number?
          • 31288
          one crystal is probably 32.768KHz for the date/time tracking, the other is probably 24MHz for the cpu
          and they are probably fine, you just need to scrape all the glue off the board.
          possible schem.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            +10
            The glue that's on your board is well known here to go conductive over time and mess up circuits. I suggest removing as much of it as possible and then cleaning the board with IPA. If that doesn't bring back the board, then we will go in further and try to see what is wrong. But with the brown glue in there, there's no telling if that's the problem or not (in many power supplies, it is, hence the suggestion to remove it.)
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
