Need help identifying polymer capacitor on motherboard
  • acamc59
    • Jun 2018
    • 7
    I need to replace a capacitor that says:
    FP10K
    19Az
    271
    16
    From my Google hunt, i think it's a 270uF 16v 10k hrs capacitor.
    Can anyone confirm this?
    Not sure was fp means nor 19Az
    Also where could i get an EXACT replacement.
    If you can't buy that exact one, would this one work? I looked on mouser and the closest one i could find is this one.
    https://www.mouser.com/ProductDetail...gbYmA8OQ%3d%3d
  • coreAngel
    • Oct 2014
    • 124
    Re: Need help identifying polymer capacitor on motherboard
    FP10K
    19Az
    271
    16
    FP is Fujitsu Polymer Capacitors (FPCAP) which was a popular Polymer cap manufacturer before getting bought out by Nichicon
    270 uf 16v is the correct one
    can you show a pic of the cap if it is possible? just to be sure
    though i would choose that cap you posted https://www.mouser.com/ProductDetail...gbYmA8OQ%3d%3d
    Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
    • acamc59
      • Jun 2018
      • 7
      So you think the one i picked is a good choice?
      Is there esr and ripple current fine for my application?
      https://imgur.com/a/7cyJO0X
      Here is a picture. They are located above the vrm heatsink. To the right and left of the 8 pin eps cpu power connector.
      I'm assuming they filter the 12v input to the board before it hits the vrm?
      • coreAngel
        • Oct 2014
        • 124
        Now this is where it gets interesting ( i didn't know it was a motherboard) your Asus ROG Rampage IV Extreme has custom Nichicon GT (it still says FP using Fujitsu Polymer) Series polymer caps, which i cant seem to find any.
        Polymer caps tend to last a very long time(this one says about 10K + hours) why do you need to replace the cap, did you do any testing?
        • acamc59
          • Jun 2018
          • 7
          The motherboard was hit in shipping at the top of the board which bent over the capacitors and pulling the leads out of the capacitor body.
          • coreAngel
            • Oct 2014
            • 124
            I looked up the motherboard caps on here
            https://rog.asus.com/articles/overcl...ampage-boards/
            I can't seem to find the caps anywhere
            However the closest thing with 5mA ripple current as it said on the page the closest thing i could find is this
            https://www.mouser.com/ProductDetail...hwM4CKJLz78%3d
            that would be my suggestion unless someone else here, has some other opinion?
            • acamc59
              • Jun 2018
              • 7
              I don't think that I'll be able to fit that one because it's 8mm diameter.
              Is there any reason to go with the ones you looked as opposed to the ones i first linked? The specs look the same but I'm not exactly sure what all the specs mean.
              Mine I linked: https://www.mouser.com/ProductDetail...gbYmA8OQ%3d%3d
              Yours: https://www.mouser.com/ProductDetail...hwM4CKJLz78%3d
              • coreAngel
                • Oct 2014
                • 124
                My mistake i thought the were different though the Ripple Current is almost the same 5.08 mA compared to 5mA so it should work great the one you linked.
                • acamc59
                  • Jun 2018
                  • 7
                  Ok I'll get those.
                  I'm also wondering, in your opinion, are the replacements on mouser considered decent for this type of application?
                  And do you happen to know what these caps do on this board? Because the board still seems to function properly.
                  • coreAngel
                    • Oct 2014
                    • 124
                    Ok I'll get those.
                    According to the Asus ROG site:
                    "Longevity is also a prime directive, so the new capacitors are rated for 10,000 hours of operation at 105゚C. Of course, since your system won't regularly reach those temperatures, expect an even longer lifespan"
                    The caps on the board are custom made and rated 10000 hours, which make no sense since most components would fail before the caps would fail.
                    The United Chemi-Con replacement is good enough, it is rated 5000 hours at 105C though the lower the temps the longer it lasts, since it is polymer caps they last much longer than electrolytics.
                    The caps filter the incoming power to the components, such as RAM,VRM's,PCI-E cards etc.
                    • acamc59
                      • Jun 2018
                      • 7
                      Sounds like they're critical to proper operation and might damage the stuff connected to the board overtime.
                        master hoarder
                        • May 2008
                        • 12175
                        270 uF and 16V - that's most likely for the CPU high-side buck converter (i.e. CPU VRM high-side). Not critical, but the board could become unstable under load, especially with a high-power CPU, if one of these caps is damaged.
                        In any case, the whole polymer thing is mostly marketing hype, among other things. I say marketing hype, because most modern motherboards just don't fail from capacitor issues anymore - they fail mainly from chipset problems (i.e. chipset going bad like graphics cards often do). But the other reason why motherboards now use poly caps instead of regular lytics is because the cost of production for polymer caps had finally caught up with that of ultra-low ESR electrolytic caps. Also, the ULESR electrolytics simply could not keep up with the demand or smaller size footprint of polymers - another reason why mobo manufacturers started using them more.
                        • chth96
                          Should I replace polymer capacitor?
                          by chth96
                          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                          Is this ESR value of polymer capacitor correct?...
                          11-18-2022, 04:22 AM
                        • Prolog
                          by Prolog
                          12-01-2024, 08:27 PM
                        • benberry24
                          surface go 2 missing capacitor, Motherboard# DA0Z93MBAE0
                          by benberry24
                          I have surface go 2 that a capacitor was nocked off. Can anyone tell me the value of the missing capacitor or if it's needed.
                          Motherboard# DA0Z93MBAE0...
                          09-12-2025, 10:16 AM
                        • Mini1
                          Fujitsu U757 - help with identifying what STM32F103 is doing. Can i replace 7th gen motherboard with 8th gen?
                          by Mini1
                          Hey. I have a Fujitsu U757 motherboard with number CP732277. And i want to replace it with U758 motherboard like with CP755900 or whatever U758 series motherboard. U747/U757(7th gen CPU) all motherboards look exactly same so i'm sure it won't matter which one to use. But i would like to upgrade a bit and get U748/U758(8th gen CPU) motherboard. Motherboards all look exactly same layout as U747/U757, but i found one chip is soldered on U747/U757 which U748/U758 doesn't have. It is STM32F103 MCU which is near screen connector. And i'm not sure will U748/U758 motherboard will work with my U757 laptop....
                          01-28-2024, 05:01 PM
                        • MORETTIGIAN
                          by MORETTIGIAN
                          Title:
                          Description:
                          Procedure performed:
                          - Removed backplate
                          - Reapplied thermal compound
                          - Reassembled card
                          09-18-2025, 12:14 PM
