Low ESR caps from Jaycar Australia
  • Neo2_000
    • Apr 2005
    • 180
    Jacar Australia now has a range (though somewhat limited) of low ESR caps.
    http://www1.jaycar.com.au
    They are branded "Samxon".
    Anyone know anything about this brand or had any experience with it?
    I guess by default, it would have to be considered untrustworthy.
    TIA,
    Neo.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Geoff was using them
    https://www.badcaps.net/forum/showthread.php?t=364
    Didnt find any data for fails on the net. You have to think however what market they are aiming for. If the price is low, the materials and construction are not going to equal one of the high brands. There is no bargain in components.
    http://www.manyue.com/
    We create, we innovate......we show pictures of chicks so you dont look to hard at the SAMXON cap specs.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
