I have someone that has a Dell optiplex gx260 that has a bad board. Looking at the board it has one bad cap on it. The cap that is bad is a rubycon 6.3 mcz 1500uf. I just recently bought some rubycon 1500uf MCZ 10v caps for another project I am working on. The cap on the dell is a small fat cap, and the caps that I bought are longer and skinny. Could I use the new caps I bought to replace the bad cap or is there a difference? The only difference is the voltage but I thought someone here said it was ok to change voltage as long as you don't go backwards.
