Paper or polypropylene or polyester caps
  • Onerous
    • Aug 2013
    • 6
    • United Kingdon
    Hola tried searching and came up with nothing.
    Looking to replace a popped Reva cap from a henry vacuum cleaner. Looking on the uk RS components site I have the choice of replacing paper with paper or the other materials. All are X2 standard.
    Does it make any difference?
    • 31213
    Re: Paper or polypropylene or polyester caps
    replace RIFA's with plastic caps from panasonic, they are very well priced at RS.
    • Onerous
      • Aug 2013
      • 6
      • United Kingdon
      That is what I was looking at. Just wasn't sure.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Is that from the 1980s, or the late-1970s? That would be the expected periods of Rifa caps that commonly fail, mainly in Apple II PSUs!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • Onerous
          • Aug 2013
          • 6
          • United Kingdon
          What do you think
          Now guess what I got from Maplinsas a replacement
            • 31213
            you actually found components at maplins? you should win a fucking prize!!!
              by momaka
              03-12-2025, 03:42 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
