Trying to identify caps
  • jarvis7
    • Feb 2015
    • 52
    • asasf
    hello ,
    Can anybody tell which brand do these caps belong to ? They are from Lenovo B40 laptop
    https://imgur.com/a/QPQ1P
    Do i have to get them replaced if i want mobo to last long or are they good as it is ? mobo manufacturing date is 3 years old
    Thanks a lot in advance
  • mariushm
    • May 2011
    • 3799
    Re: Trying to identify caps
    Those are most likely polymer capacitors, which typically don't break as often as electrolytic capacitors and don't have to be replaced.
    Don't know the manufacturer, the pinkish ones may be Enesol or Teapo polymer capacitors but can't match with particular series.
    The black ones can be anyone's guess but probably Nichicon or Samwha or something like that.
    Either way, they should match what's said on them, 33uF / 25v , 68uF/25v, 220uF 6.3v etc etc
    If they're bad, you can replace with any generic polymer low esr capacitor of same value and voltage rating (or slightly higher voltage rating)
    • jarvis7
      • Feb 2015
      • 52
      • asasf
      Thank you sir for your reply
      They are currently not bad , but i was wondering if they were Sacon or some other very poor quality type polymers then should i replace them ... if they will easily last 3 more years then i'll just leave them there
