Samxon GA
  • slavun
    • Feb 2009
    Samxon GA
    Hi to All,
    This is my first post here. I would like to know whether it is good to replace KZG's with Samxon GA for the Vcore(the ESR difference is nearly twice). My board is DFI NF2 Infinity and the caps are almost "dead".
    http://www.bgsportal.blogspot.com/
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Samxon GA
    That's a good choice.
    Mann-Made Global Warming.
    - Dr Seuss
    • hayrieker
      Infinity M7-11R7N-888 (GM7TN7)
      by hayrieker
      Hello, I need Infinity M7-11R7N-888 bios. serial no : GM7TN7M2213600193
      Attached original bios from motherboard, and pictures
      the problem is no power on. 3v, 5v, 1.8v are comming. there is no any short, I read 00.10 ah on my power suppley (dps5020)
      So I think bios is damaged. If you have an idea pls help me. Regard masters....
      09-12-2025, 08:21 AM
    • vlady carp
      Looking for Dump for P87C51SBPN (Concord Infinity Elevator)
      by vlady carp
      Hello, colleagues!
      I'm currently dealing with an issue while repairing a Concord Infinity elevator. The microcontroller P87C51SBPN used in the control board has failed, and I need the original firmware dump in .bin format to replace it with a new processor.
      What I've done so far:
      • Diagnosed the issue and confirmed the microcontroller is the root cause of the problem.
      • The original processor is beyond repair, and I wasn't able to extract the dump.
      • Reached out to the manufacturer (Savaria/Concord), but I haven't received a response yet.
      01-16-2025, 02:08 AM
    • chth96
      Can I replace KME cap with Samxon GF cap?
      by chth96
      Hello.
      I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
      Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
      I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
      04-17-2024, 07:11 AM
    • Omar Villalba
      Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA) schematic
      by Omar Villalba
      Good morning, colleagues.
      I'm looking for the schematic or boardview for a Dell Alienware M16 R1 AMD (Infinity A+N MB1 213199-1 Y5J11$CA).
      I would really appreciate it if someone could share it.
      My main issue is that the backlight is not working. I found fuse F5503 to be blown; I replaced it, but it blows again (goes into protection).
      It's worth noting that there's no short on the fuse line, so any guidance or similar experience would be greatly appreciated.
      08-12-2025, 09:21 AM
    • GEARELECTRONICS
      Samxon capacitor esr
      by GEARELECTRONICS
      I need your advice.
      -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
      -Is this esr reading realistic?
      Thank you
      05-29-2023, 07:26 AM
