G-Luxon LL-Series datasheet/replacement?
  • DSO
    • Nov 2017
    • 6
    • Sweden
    Hello!
    I'm changing capacitors on an E-MU 1820m soundcard/breakout-box with G-Luxons in it. Much thanks to this board for providing information on the matter, otherwise I might not have dared starting this project.
    I've found the datasheets for a lot of G-Luxons, but can't find any mention of the following capacitor apart from on this very forum, for the exact same box(!): https://www.badcaps.net/forum/showth...light=LL85%B0C
    The markings on the capacitors are
    G-LUXON 63v 100uF LL85°C 308K(M)
    Does anyone know what this might be? I've googled to the best of my abilities but turned up empty handed.
    Currently considering not replacing them cause I can't find any information on them, and they are in the audio path (the black connectors are XLR connectors for two microphone inputs), with currently no known faults.
    The largest thread I've found on this break-out box doesn't contain any mention of this capacitor, but is here if someone is curious: https://www.badcaps.net/forum/showthread.php?t=10362
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: G-Luxon LL-Series datasheet/replacement?
    I attached the G-Luxon LL datasheet. It is a low leakage current 85ºC series to which Chemicon's LLA series is a direct cross. Haplessly, the case size for 100uF 6.3V in the datasheet does not match those in that breakout box.
    • DSO
      • Nov 2017
      • 6
      • Sweden
      Thank you very much! (They do match though, as I need 63V and not 6.3V - and the dimensions for 63V match.)
      Now I just need to figure out a suitable replacement, the ones in my preferred stores seem to be rated for a leakage current "<= 0.01CV (or 4µA, whichever is greater)", whereas these G-Luxon LLs are "<= 0.002CV (or 4µA)" and I'm not sure how much this matters.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        Wow, I feel so dyslexic now. I don’t know how I missed the fact that there was no space between the 6 and 3 on the voltage rating. In that case, it turns out that Nichicon’s KL series may be a better replacement. Mouser has some in stock.
        • DSO
          • Nov 2017
          • 6
          • Sweden
          Thanks! Might have to change to Mouser then and find some more things to avoid the shipping charge
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • ezenia
            PS4 controller left stick potentiometer replacement issue
            by ezenia
            Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
            So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
            I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
            09-30-2023, 02:19 PM
          • boosti45
            Macbook pro logic board replacement parts quesion
            by boosti45
            i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
            08-21-2024, 05:23 AM
          • the_rem
            Unknown transformer : how to find a good replacement part ?
            by the_rem
            Hello guys,
            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
            04-23-2025, 01:48 AM
          • r2digital
            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
            by r2digital
            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
            04-18-2024, 03:50 PM
