Cap series? voltage?
  • vinbar1
    • Jan 2009
    Do you have to replace a cap with the same series or can i replace an EB series cap with a FC series cap?
    If I cant find the right voltage do I use the closest one up or lower?
    If I neet to replace a 16v and only can find 10v or 25v what one would i use?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Cap series? voltage?
    You can use a different series, just check that ESR, ripple current and temperature are similar or better than the series you are replacing
    It depends: to be sure you must check or you must know what voltage is applied: on VRM output you can find 10V caps but you can use 6.3V without problem and vice versa, it is important that the replacement has the same or lower ESR and the same or greater value let's say +20%.
    On the last parameter (value) there are different opinion AFAIK so don't increase uF too much.
    For sure you must use 25V otherwise the cap blown up!!
    If you read some posts you will learn much more about these questions.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • Prott
      PCB Layer to layer short on a low voltage power plane - how to find it?
      by Prott
      Hello!
      Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
      Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
      Silly idea no. 1: Can I...
      08-01-2024, 12:09 PM
      ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
      This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-12-2024, 03:28 PM
    • allietti
      EVGA 3080 Memory replace but i dont know where to find out
      by allietti
      Hi team. i have a EVGA RTX 3080 with 2 IC in short i need to replace but i dont know how to find to buy. the IC only said AL00 1D4H nothing else ii supouse is a memory IC but i dont know. i attach pictures for more information if you can help i really appreciate....
      03-10-2025, 07:57 AM
