Part ID question
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Part ID question
    Ran into a part I don't know the OEM or type.
    Attached is a photo.
    Not the big orange caps, but the little ones near the center, that look like they were intended for through hole pc mount.
    This is part of a modulator for a Harris broadcast transmitter.
    Thanks in advance.
    Jack Crow
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • 31294
    Re: Part ID question
    film capacitors
    • redwire
      • 3912
      I see the Orange Drop and CDE silver mica caps, but not sure about these ones.
      Label is 4.7M or 47M 50V which is too small in value for film caps?
      It has 3 camel humps like maybe ferrite bead inside, square base. Hmmm.
        • 31294
        meter one.
        • -=kratos=-
          • May 2017
          • 13
          • Piphilippines
          i think its polyester film capacitor
          • petehall347
            • Jan 2015
            • 4450
            • United Kingdom
            films dont go bad as far as i know
            • Jack Crow
              It's a CLASOB!
              • May 2008
              • 823
              Pete,
              Apparently the prior maintainer of this transmitter went out of his way to screw this thing up. So most anything can happen.
              Jack Crow
              The Masso
              Mayor John Almafi
              MC Hawking
              • Jack Crow
                It's a CLASOB!
                • May 2008
                • 823
                Originally posted by stj
                film capacitors
                STJ and company,
                I passed on your answer and the others to Earl, one of my shop mates who is doing the actual work.
                Was able to find a vendor for the parts.
                Many thanks to all for the heads up.
                Jack Crow
                The Masso
                Mayor John Almafi
                MC Hawking
                • R_J
                  • 9625
                  They look similar to these Sprague .047uf 50V Monolithic Ceramic Capacitors
                  • redwire
                    • 3912
                    I think they are Sprague disc capacitor, Z5U 50V 20% nothing special.
                    A 0.047uF one is 7CZ5U473X0050DC
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
                    • G-Sting
                      iPad Pro A1876 SHORT Part Identify Help Needed
                      by G-Sting
                      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                      SO My main concern is what part should i order what should i search the name for ?
                      on Ipad...
                      05-15-2025, 09:30 AM
                    • BOSCHNJAK
                      by BOSCHNJAK
                      ABOUT ME INTRODUCTION FILE
                      2
                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                      2022 BEV, PROJECT ?
                      2021 BEV, PROJECT ?
                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                      12-28-2023, 02:09 PM
                    • Yanleb
                      Panasonic part number in service manuals
                      by Yanleb
                      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                      For an example, look at the attached PDF.
                      Do you have a way to cross reference the Panasonic part number with the actual part number?
                      Thanks....
                      07-03-2023, 08:16 PM
                    • FreakyMex
                      Trouble to identify part (Lunii screen) for replacement
                      by FreakyMex
                      Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                      I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                      02-17-2025, 01:16 AM
